Side window question for early Longbridge BN4
blueskies
Still working on the finishing touches for the Longbridge BN4 - serial number 342**. I'm a bit confused about what side windows might have been original for this car. I have five or six sets of side windows to choose from. They range in condition from two relatively new reproduction sets that came with different cars down to what may be an original set of second style Longbridge side windows. That set has one fixed pane and the unique style of mounting arms (with an open slot on the rear arm, etc.), but they are in rough condition. This set fits the description given by Anderson and Moment, except that they do not have the "Weathershields Reg'd Design" markings described by Anderson and Moment.
One other older set is in fairly good condition, and I just finished buffing and polishing the plexiglas and installing new weatherstrip on this set. This set has the "Weathershields Reg'd Design" embossed on both frames. But both front and back panes slide and the windows have the newer style fastening arms. That makes me think that they are original Healey factory parts, but for what? With the two sliding panes, they likely are not correct for the BN4. Or are they?
I will post a few pictures below. The first one is of what may be the original windows for the car. The next two pictures are of the "Weathershields Reg'd Design" windows that I may use, at least for now, on the BN4. The fourth picture is of the set that came with my BT7. I suspect that it is a new reproduction set. What makes it different from all the other sets is that it has rubber weatherstrip on all four sides. I wonder if that is correct for anything?
Any help sorting this out will be appreciated.
B
blueskies
Thanks, johnea. I had seen those pages. But Anderson and Moment complicate it by saying that Healey changed the side window design three times just during the relatively short time of Longbridge production of BN4 cars. And they appear to add the "Weathershields Reg'd Design" element, which my earlier style side window does not have but one of the other examples in my pictures posted above does have. Maybe none of them actually had that name embossed?? I don't know but maybe someone else does know. I probably will rebuild and use the side windows shown in my first picture, but am trying to gather more information before investing the effort in that. Also wondering what the two other examples pictured are correct for.
John Turney
I also have a BN4 (349**). My sidescreens are like the first photo, except they are re-anodized and the arms are re-chromed. Only the front perspex slides, not both pieces. They do not have the "Weathershields Reg'd Design", at least that I can see. The later sidescreens have the arms like in the third photo and both front and rear panels slide.
B
blueskies
John, thanks for the reply. I agree that the sidecurtains that you have (and those in my first photo) probably are the correct style for this range of Longbridge cars. So, today, I began rebuilding those sidescreens.
Rather than attempt to remove all the scratches, I plan to use new plexiglas. Another set of weatherstrip is on order as well. These sidescreens use brackets in the corners - similar brackets to those used in the windshield frames. All of the brackets - except for one that is missing (which will require making a new one) are in good condition.
In the past, I have had success with refurbishing aluminum by sanding, followed with buffing compound and a power buffer, and finally coating with a protective coating to help prevent oxidation. I will try this on these side window frames. The aluminum parts did require a lot of hand sanding (afraid to use a power sander on them for fear of removing too much metal). Buffing will come next. The four mounting arms (coated or chromed steel) cleaned up beautifully and now have a nice shine.
HealeyRick BJ7 Side Window Alignment Austin Healey 31
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
D BJ 8 Side window broken - Help !! Austin Healey 9
TRclassic3 Side curtain window Triumph 9
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
B BJ7/8 side window glass Austin Healey 6
STL_Joe Spitfire Spitfire 4 Side Window Glass Triumph 3
AngliaGT MGB-GT GT Rear Side Window Gaskets MG 2
T Door side vent window Mlll Midget Restoration & Tools 4
M Side Window Questions Spridgets 3
R installation of side window rubber water sweep Austin Healey 0
R Side window seal installation problem. Austin Healey 20
D SIDE WINDOW GLAZING STRIPS Austin Healey 2
T Gasket channel for coupe side window ? Jaguar 5
K TR2/3/3A Side view mirrors again Triumph 8
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
Walter74 AH Spares Side Exhaust Austin Healey 2
R MGB side chrome installation MG 4
W Need advice on installing new side curtain glass Spridgets 1
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
kodpkd Side Curtain Windows Austin Healey 11
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
D Rear Seat Side Panels, BT7 Austin Healey 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
D BT7 Rear Side Panels Austin Healey 0
T MGA Unknow side screen MG 6
K TR2/3/3A "Clip on" style side mirror? Triumph 9
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R Grounding Side Lights Austin Healey 4
R bugeye side lights. Spridgets 0
R side light install Spridgets 2
Fanch00 Noisy Side Screens Austin Healey 13
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
madhouse 100-Six Side Curtains Austin Healey 8
R MGA MGA Headrest fairing for R/H side MG 0
S TR2/3/3A foot well driver side carpet Triumph 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR2/3/3A tr3 side curtains Triumph 4
Healey Nut Side Screens Austin Healey 12
