Results 1 to 5 of 5
Thread: Please help --- New owner of a 1958 Austin Healey Sprite
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Feb 2020
    Location
    Oceanside, CA
    Posts
    2
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hello everyone, I'm a proud new owner of a 1958 Austin Healey Sprite. It is equipped with a 1275 BMC motor, 45 DCOE Weber, mild cam, tube header, Datsun 5-spd and front disk brakes.
    I am having an issue with the RPMs upon start. It warms up fine to 160, but I have to give it gas the whole time. Then after a few minutes, it should settle at idle (1k RPMs?), but it sputters out and dies. Car was not driven much in the past 3 years. I filled tank with 91 Octane, but had about 2 or 3 gallons of old gas. Any ideas of what might be going on here? Where to start?
    Very much appreciate any advice you may have!
    Cheers!
    Jerry A.
    p.s. I have a short 2-min video posted to YouTube https://youtu.be/UK6EonBp-D0
  2. #2
    Yoda Trevor Jessie's Avatar
    Join Date
    Nov 2003
    Location
    Louisville KY
    Posts
    8,086
    Thanks Thanks Given
    2
    Thanked in
    Re: Please help --- New owner of a 1958 Austin Healey Sprite
    Check the plugs. If they are fouled, put in a clean set and see how it runs. Then check them again and see if they indicate a problem.
    _____________________
    1970/2 MG Midget
    Datsun 5-speed
    Future Fuel Injection Turbo Project
    _________________
    1958/9 Sprite AN5L/1499
    1275 SuperCharged
    Datsun 5-speed
    _________________
  3. #3
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,198
    Thanks Thanks Given
    36
    73
    Thanked in
    Congrats on a great 'base' to work with! A well set up 1275 in a Spridget chassis is something really special.
    Even from the inherently poor quality of YouTube audio, it's apparent that thing is running wildly over-rich down at low end rev's. Compound that with old fuel and it's no surprise it runs that way.
    I'd be curious to know how the Weber is jetted. A 45 is kinda overkill for a mildly set up 1275. A 40 would be more than adequate.
    The oil pressure indicated in the video seems a bit "lazy" on revving, idle is good but it should be closer to 60~70 PSI nearly instantly on revving to 2800~3500 RPM. A modified oil pump may be the reason, more volume at lower pressure. Hunt for Clive Trickey's books on that, Good explanations and illustrations.
    By all means, do some plug swaps, invest in a pair of "ColourTune" tools to help set up idle jets and mixtures with that Weber. Another thing to look at is the choke pistons in the carbs. Make sure they're fully seated. If not, they can leak fuel past the idle circuit.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  4. #4
    Join Date
    Feb 2020
    Location
    Oceanside, CA
    Posts
    2
    Thanks Thanks Given
    Thanked in
    Thank you guys for the great insight. As I said, I really am new to the circuit and have everything to learn (from scratch). I am by no means "qualified" yet (or brave enough) to attempt tinkering on this beauty, but have an appointment with a well-qualified British repair shop in San Marcos -- not too far from me in Oceanside. The shop owner did warn me not to run it any longer, until he gets his hands on it, to minimize any potential (further) harm. Here is a pic of the sickly Sprite...
  5. #5
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    33,198
    Thanks Thanks Given
    36
    73
    Thanked in
    Quote Originally Posted by newb
    That alone gives an indication you may have a good place to take it. Keep us up on what goes on with it! Really curious as to what they have to say about the Weber jetting and the oil pressure. Be sure to show them your video.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
