Results 1 to 12 of 12
Thread: DIL's O2 sensor problem - SOLVED
This is a forum for discussing cars that are not British. Discuss anything from Mazda to Corvettes or anything in between here.
  1. #1
    Administrator Basil's Avatar
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    24,427
    Blog Entries
    7
    Thanks Thanks Given
    62
    Thanks Thanks Received
    112
    Thanked in
    My DIL's 2004 Grand Prix was throwing codes indicating a bad O2 sensor and O2 sensor heater circuit (initially just the Upstream sensor). I replaced the upstream sensor but the problem persisted and in fact now both sensor heater circuits were showing bad. Her uncle took it to his "expert" mechanic who changed the sensor again and supposedly checked the wiring - after a couple weeks, and several hundred $$ in troubleshooting costs, he could not fix the problem and was talking about all kinds of things like replacing the MAF or the Cat, etc. Well, her Dad didn't want to sink any more money into it so I got the car back and started doing some more in-depth troubleshooting. What I discovered was that there was no power getting to the heater circuit at the female plug on the harness that the O2 sensor plugs in to. The fuse was good, so I started checking the wire harness closely. I found a spot on the underside of the harness where the harness had rubbed against the serpentine belt at some point and the belt had cut through the harness and literally cut the wire leading from the fuse box to the O2 sensor female plug (the sensor heater circuit). I soldered in a splice of wire and checked the continuity and it was all good!
    FIXED! Or so I thought! I was still not getting 12v to the O2 sensor plug. The fuse was good, so what was going on? Well, I pulled the fuse and stuck a paper clip into the hot side of the fuse receptor and was getting 12v as I should! But, when I plugged in the fuse and measured at the top of the fuse (the little metal point on top the fuse where you can check voltage), there was 0 volts! Ahah! The problem was a worn female contact on the fuse box for the O2 sensor heater circuit fuse! Not wanting to replace the entire fuse box, I devised a jury rig to address the problem. I went to NAPA and bought some little "fuse taps" and shoved a fuse tap into the hot-side slot, then plugged in the fuse and there was now sufficient contact to provide 12v at the fuse and hence 12v at the O2 sensor plug! Reset the codes and viola - it's been working fine ever since.
    The smallest act of kindness is worth more than the grandest intention. - Oscar Wilde
  2. #2
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,468
    Blog Entries
    1
    Thanks Thanks Given
    78
    115
    Thanked in
    Re: DIL's O2 sensor problem - SOLVED
    Congrats on the victory. But it re-inforces my thoughts on trouble-shooting based on codes. Sometimes it's not the engine that has the problem - it's the diagnosis system!
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  3. #3
    Yoda Gliderman8's Avatar
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,537
    Thanks Thanks Given
    11
    38
    Thanked in
    Great work Bas! I love it when you can keep backtracking in order to find the cause of the problem. Most of the time they turn out to be simple but its only simple once you find the real problem.
    Good stuff!!
    Elliot
    Central PA
    1973 TR6 Damson Plum / Biscuit interior, HVDA 5-speed, Good Parts Hubs
    1976 TR6 White/Biscuit interior SOLD
    Nostalgia isn't what it used to be.
  4. #4
    Darth Vader Bayless's Avatar
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,615
    Thanks Thanks Given
    14
    Thanked in
    Nice job Bas.
    Was Man nicht im Kopf hat muss Man in den Beinen haben
    '48 Ford Prefect
    '67 Sprite (project)
    '74 Super Beetle
    http://enfoprefect.org
  5. #5
    Luke Skywalker LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,971
    Thanks Thanks Given
    16
    Thanked in
    Shops don't take the time to investigate these wiring problems because either, they don't know how or they know the customer is not going to pay for time to do it. Any car over 10 yrs old is not held to a book flat rate anymore due to age and corrosion of bolts.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual ,
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  6. #6
    Yoda waltesefalcon's Avatar
    Join Date
    May 2002
    Location
    Fletcher, Oklahoma
    Posts
    5,709
    Thanks Thanks Given
    547
    7
    Thanked in
    Quote Originally Posted by LarryK View Post
    Exactly, chasing down these faults is a PITA and at the regular rate of $60 an hour will cost a small fortune to find unless the mechanic is just lucky right out of the gate.
    Cheers,
    Walter
    52 International L110
    68 Cadillac Coupe DeVille
    96 Mazda Miata
  7. #7
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,615
    Thanks Thanks Given
    14
    Thanked in
    Good luck on finding a mechanic at $60/hour these days.
    '48 Ford Prefect
    '74 Super Beetle
  8. #8
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,971
    Thanks Thanks Given
    16
    Thanked in
    They are around, but remote and pretty much recommended word of mouth. Our average here for indy shops is $50-$75. Specilaized or really good indy shops are $160, same as dealers. I know of one in the next town at $45, but do not, repeat do not be in a hurry. My sign say $85 an hour, vintage British only, stops BS and wanta favors.
    Larry K
  9. #9
    Join Date
    May 2002
    Location
    Fletcher, Oklahoma
    Posts
    5,709
    Thanks Thanks Given
    547
    7
    Thanked in
    I do suppose it's been fifteen years or so since I was a mechanic, so my pricing may be a bit off.
    Cheers,
    Walter
    96 Mazda Miata
  10. #10
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,971
    Thanks Thanks Given
    16
    Thanked in
    Prices vary from area to area. I ince went to Burkesville, KY to fish at Dale Hollow Lake. Knew I had a bad u-joint in the van. Once we set camp we drove into town for supplies and I stopped at a one garage station with a bunch of gearheads sitting around. Asked if they could put in a u-joint while the wife and I shopped at the store a block down. Sure they said but part store closed, said I have the joint and they took over. Went shopping and bought an extra six pack, went back they were done. How much? $10. Easiest u-joint I ever replaced. Tipped them a six pack. Everytime we went into town they would wave and holler.
    Larry K
  11. #11
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,738
    Thanks Thanks Given
    9
    16
    Thanked in
    Quote Originally Posted by NutmegCT View Post
    +1 ON THAT AND LOVE THAT DARTBOARD. The OBD systems seem to have gotten better after about 2010, IMO, the down side being that the tools have also become more expensive and model specific.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  12. #12
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,971
    Thanks Thanks Given
    16
    Thanked in
    Agree on the specialized O2 tools especially. Just bought a set supposedly to handle all types. Old ones were not capable of reaching or too short. Just bought another scanner just for BMW/MINIs so I can reset more programs on my wifes 2011. Not cheap either.
    Larry K
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
