Bugeye [style] gauges in a Box Sprite?
Pythias
These
https://bugeyeguyparts.com/products/gps-bugeye-speedometer
I'm about to order the GPS speedo and electronic tach from above so that I can have accurate gauges in "the red thing". I know that Spridgets are mix and match as far as parts go, but was wondering what the opinions of the members here have about the esthetics of putting this style gauge in a box sprite.
It's not that I won't still do it if it is not given your approval, I'm just looking for opinions.
I know you have some.
Will also, because the tach is negative ground only, be changing polarity of the vehicle. I plan to get his "Genernator"
https://bugeyeguyparts.com/products/genernator
Thoughts?
Rut
Bill,
I think Speedhut and Autometer both make gps speedos with a face like that...I believe Jim Gruber is using one. They would look good to me in a box Sprite.
Rut
59diamond
I have a genernator on my Bugeye and it works great. They come in positive and negative ground so make sure you get the right one. Mine is negative.
Jim_Gruber
But the Gauges in a Box Sprite are a different Size than in a Bugeye. You can get custom gauge faces from Speedhut for a nominal fee. And if you get on the Speedhut Mailing List they run 20% Discounts on holiday weekends. Measure the size of the openings. Something tells me that Spridget Gauges are 4" and Bugeyes are 3.5" Measure please before you order. Here are pics of my Speedhut Gauges. Bugeye Guy has a customized Gauge Face but you may be able to get from Speedhut. These look really good on my new Red Dash. Speedhut Speedo.JPGSpeedhut Tach.jpg
Pythias
Pythias
I have been looking at the SpeedHut gauges for years but didn't know that one could get them customized beyond their menu system. How did you do that? Did you have to call them? did you send a picture? can you send a picture? will they do them from pictures of Smith's gauges?
Do you remember the specifics of what you ordered? I want... I want.
Pythias
Pythias
Weren't the Mark II Sprite/Mark I midget dash and instruments pretty similar to Bugeye?
They may have been, but I have a Mark III Sprite.
Billm
The gauge sizes were the same bugeye thru '67. It was in '68 that the bigger gauges got smaller
Jim_Gruber
Thanks Bill, my first Sprite was a ‘68 with a padded dash. That’s why I was confused. I added a few options to gauges including on the Speedo a blue led for bright light as well as Green LEDs for L and R turn signals, as well as the Austin Healey Script. The tach got a red generator/alternator lamp remember you need an analog bulb in the line going there as an exciter for the a,ternator / Generator before going to the LED. And again added the Austin Healey Script logo. The center disc is one of the options you can choose. David’s is si ply a little larger I think than standard.
Pythias
Pythias
Here's what I came up with from Speed Hut. I picked a different logo. But if the ones from Bug Eye Guy fit, I'll probably go that way.
I don't see a way to add the charging light to the tach.. Hmmmm.
However, if I read the message from Bill M correctly, Bug Eye gauges and Mark III gauges are the same size, 4" and I'll probably go with the ones from BugEye Guy.
Jim_Gruber
Let me pull my dash off the shelf in the am and measure for you. I can unscrew the tach easily and measure the size of the opening. I might have ordered 3 3/4” size. The logo I just pulled off of the internet and sent them the file. They photoshopped the image to make it fit and so there was room for the LED’s to look nice. See if they can pull up my order in their files and copy the artwork if you like how it looks. Hmm order would have been in 2017 I think and I still lived in OH. See if they still have this artwork on file. I’ll check the opening size in the am for you.
James Gruber
3656 Echo Hill Lane
Beavercreek, OH 45430
Jim_Gruber
I’ll also look and see if I still have the eMail with the final proofs.
Pythias
Pythias
Update. I decided to go with the gauges from Bugeye Guy. Also changing to positive ground, installing Genernator, and redoing dash crinkle finish. I have to change the Crane ignition to a negative ground or universal one to make the polarity swop, so a new one of those too.
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
