Steering column steady brace and scuttle shake?
steveg
A friend realized he was missing this and made one from hardware store flat steel.
He reports it has reduced shake and play in his steering. Lack of this brace might be a contributing factor in the infamous scuttle shake.
Dimension is 11-7/16" on outside of bends.
Refer to Moss "Front Body Fittings 100-6, 3000" page, item# 200
BJ8Healeys
I have that piece in my BJ8 and still had scuttle shake. If scuttle shake exists and the piece is missing, the steering column would vibrate more, for sure. What fixed the shake for me was:
1. Having Allen Hendrix true and balance all my tires and wheels.
2. Taking advantage of having the engine out for rebuild and incorporating the "Bill Bolton" mod to the firewall structure surrounding the opening for the gearbox bellhousing. This involves welding 3/4" angle iron around the opening with angle iron gussets in the upper corners, and welding the sheet metal seams in the firewall continuously (to replace the stitch welds that are intermittent). This mod is not visible with the engine and gearbox installed, and I have zero scuttle shake now at any speed.
CLEAH
More regarding Steve’s #2 comment above:
I learned a lot about scuttle shake when I disassembled my car prior to sending it off for restoration. I learned even more when I did some of the structural welding. When the chassis is sitting bare on the floor, you can really see where scuttle shake comes from. The scuttle is actually the front bulkhead, which is made up of lots of pressings, triangulations, braces, hinge pillars, etc. The bulkhead is connected to the main frame sections and sills in only a few spots, and over time those spots (and of course any of the other key components like sills) can rust and weaken. The rigidity of the bulkhead is lost, and then things like out-of-round wheels or potholes in the road telegraph through the structure and make the scuttle wobble. Again, when you see the complete structural system before you, it is pretty clear where scuttle shake comes from.
In my case, a complete professional restoration resolved scuttle shake on my car. It is very tight, which is not a term I ever thought I would use in reference to a Healey. It is good to know from Steve’s comments that there are remedies short of a complete restoration. But I imagine Steve’s car was already in good condition. The entire system needs to be extremely sound or you will get scuttle shake. And yes, get good wheels from Hendrix!
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
T TR2/3/3A Steering Column Grommet Triumph 4
D Ajustable Steering Column Escutcheon Austin Healey 2
6 Steering Column Spridgets 6
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
