BT7 Door Seal Installation
BT7Doug
I would like to replace the door seal on my "62 (manufactured in July '61 and a side shifter) Tri Carb BT7 and am having trouble figuring out how to terminate the door seal behind the seats. The restoration manual is not helpful either; the pictures are indistinct and I am not sure my model is represented. In the restoration manual and in pictures I have found of what I believe to be 61-62 BT7s, the trim appears to disappear under a silver cap mounted with 3 screws. I can not find that part in the Moss catalogue. The restoration manual talks about something being attached to a block of wood. No wood block on my car.
Attached is a picture of my driver side door (red vehicle) showing the trim and the attachment hole for the tonneau cover. Also attached is an internet picture of this mysterious silver coloured block in what is claimed to be a '62 BT7. Moss sells some miscellaneous trim fittings but for the life of me I cannot figure where they go on my car. I added a picture of those too. With the trim ending like it is, getting in and out of the car just trashes it and it clearly needs to be properly terminated. If anyone can send me a picture of what the original production solution looked like or provide a description on what I need to do, I will be eternally grateful.
blueskies
Here are a couple of pictures of that area on my 1961 BT7. It looks as if my car may be missing the aluminum top finisher pieces that you show in your second picture. Come to think of it, I have seen one or two pieces like that finisher in the spare parts collection. In any case, it looks as if your weatherstrip does not extend far enough up the door post to make the turn to the back.
Rob Glasgow
Here is a shot of that area of my BT7 before my last restoration. You can see the wooden block that the aluminum cap sits on. The small hole in the second photo is for the sheet metal screw that holds the block to the inner fender top plate. Also the black weatherstripping that mounts between the door finisher and the rear fender should continue up and loop around the top edge above the single screw. In my photo that portion of the weatherstrip has worn away so doesn't show up.
blueskies
The door seal cap Moss part numbers are 021-785 (R/H) and 021-784 (L/H). Red Bristleflex door seal, sold by the foot, is 249-695. Other colors have different part numbers. Not recommending any particular supplier; the other suppliers probably also have the parts. Hope this helps.
B
BT7Doug
Thanks to both of you for that information. This is the first view I have had of that block of wood. I will have a look under the fender to see if there are residual hole signs. When I purchased the car the carpeting was not included in that little shelf, just paint. The carpet kit I purchased cover the entire shelf so the block could go on top. Or I could install the wood and trim the carpeting back. Any opinion? And thanks too for find the part number for those caps. This will really tidy up the installation of that trim.
Rob Glasgow
The block goes on before the carpet. You should be able to remove the carpet piece without disturbing the block or aluminum cap.
B
BT7Doug
I had found that site but not really sure what the different blocks are for. A really old post on this site suggested that the block is covered with the vinyl used on the cockpit trim. I am going to order the hardware and then cut a block of the appropriate size with some oak if I can find it. I will try wrapping it in vinyl much like that block in the truck which supports the tire at the back. I will post a pic if it works. Thanks for the help
Doug
Rob Glasgow
There are two blocks per side. One goes under The aluminum finisher cap like in my photo. I don't remember if it originally was covered with vinyl but it may have been since some of it is exposed. I just painted mine a dark blue to match the interior vinyl. I do have a vague memory of them being covered in vinyl but my first interior restoration was 40 years ago so I can't be sure.
The other wedge shaped block goes up under the side of the rear surround and aluminum cockpit trim and is there to hold the top bow in place when it's stowed in the hood down position. You should also be able to locate some screws holes up under the cockpit sides. I don't believe these were ever painted or covered since you can't see them.
B
BT7Doug
Thanks Rob,
I received the blocks and have them installed. I will install the trim and the aluminum caps as soon as I find the suitable retaining screws. Do you or anyone else have a picture of where the wedge shape pieces go? I could not find the mentioned screw holes.
I hope everyone is staying safe and healthy. Since we have to stay home we may as well mess around with our cars
Lin
Doug, These photos show where he wedge shape pieces of wood go. This photo is from around 2002-03 when I started the restoration of my 60 BT7. These are the original blocks in original location. Hope this helps.
Lin
B
BT7Doug
Thanks Lin, exactly what I was looking for. It looks like the screw holes have been painted over on my machine but I will find them. The correct finish is likely vinyl so will investigate that after I discover the holes.
Doug
Lin
Doug, the wooden blocks under the aluminum finisher were covered in vinyl on my car, but no vinyl on the blocks that hold the soft top frame in place. Just painted body color.
B
BT7Doug
Here is the left block in place. Fit snuggly as the carpeting is already installed. A vinyl cover would make it even tighter. Does anyone know the purpose of these blocks? My soft top frame is stowed and does not seem to have anything to do with the blocks.
MadRiver BT7 Fuzzy Door Seal Install Question Austin Healey 1
P BT7 Door seal Austin Healey 15
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
Lin BT7 furflex/rubber door seals Austin Healey 17
D Door seals bt7 Austin Healey 4
M BT7 Aluminium Door Trim Austin Healey 1
J Door Handle Removal - BT7 Austin Healey 6
P BT7 door pillar cap installation Austin Healey 3
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
