BigCountryBritish
Late TR3 motor with the exposed end on the starter. About 1/2 the time the starter will spin free without engaging the flywheel, the rest of this time it grabs and does a fine job of cranking and starting the car. I had the starter on the bench during the recent re-build and seems to operate as it should, the ring gears are all fine, no missing teeth.
The only remedy I have tried is to lubricate the end that is visible with some spray lithium grease. Not sure what to try as it is not 100% failure.
All suggestions appreciated.
Bill B
TS75131E
Bill B
TS75131E
