TR2/3/3A Question on torquing nut on steering box rocker shaft
TuffTR250
When torquing the large nut on the steering box rocker shaft (Macy's says 80 lbs) is it necessary, or possible, to somehow hold the rocker shaft so pressure is not put on the arm of the rocker shaft, rocker peg, and worm gear? Thanks!
CJD
I hold the arm in a table vice while tightening. Of course the box has to be out of the car for that.
sp53
I think 80+ should be enough and then bend over the locking tab on the nut. There should be wiggle room before the pin contacts the worm. The final adjustment is made with the nut on the cover that pushes down on the arm to make the final contact. There is also a high point in the very center when you make the final adjustment; you should feel that rub with the tires up and moving the steering wheel left and right
TR3driver
Great Pumpkin - R.I.P
Another approach is to lift the arm so the peg is out of the worm groove, and let it rest against the side of the box.
My feeling is that tight enough to feel from that great big steering wheel is too tight; I like to feel for the tight spot with just my fingers on the splines and the box disconnected from the rest of the steering. Might get a tiny bit more play that way, but also less drag and maybe even less wear.
Note that if the worm is substantially worn, the tight spot may be off to the side a bit, or even two tight spots. So check throughout the range of motion.
T
TuffTR250
My steering box is still out of the car, but fully assembled. Today I adjusted the screw on the top of the steering box for when the Rocker shaft was in the middle, it took 1/4 turn of the screw to tighten the shaft to where the worm could not be turned by hand even with quite some hand force. When I re-backed if off the 1/4 turn the worm shaft turned easily by hand. With the screw backed off from full down by 1/4 turn, I could not feel any movement of the rotator shaft when I tried movement of the drop arm. When I moved the rotator shaft lever off center about half way, I could then feel some slight wiggle movement of the rotator shaft peg against the worm gear. Does that sound about right for the adjustment of the adjusting screw? Thanks!
TR3driver
That's pretty close.
IMO, you be able to just feel the bind in the center, while turning the shaft with your fingers; but still be able to turn through the tight spot without too much effort.
The problem is that even .004" of vertical movement, which is too small to feel with your hands (at least for me), will still result in some play on the steering. You want that clearance going to exactly zero, or even a very slight preload.
CJD
+1. Adjust the bolt so you can feel the center, yet still able to turn the shaft without the steering wheel. It can be on the tight side while just turning the bare shaft. Once you ad the wheel, it will be imperceptible.
The reason you feel play off center is that the steering is designed with a natural desire to return to center, so even though there is play, the peg will stay against the worm on one side. At center there is no force to keep the steering at center, so all play must be removed or the car will wander.
T
TuffTR250
Thanks for the responses!! I will try tightening the top cover adjustment screw just a bit more and see how that works.
T TR4/4A Question on re-torquing the head if it has leaked Triumph 18
JPSmit re-torquing question Spridgets 2
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
