Results 1 to 9 of 9
Thread: OD angle drive engaging the speedo cable
Discussions of Triumph motor cars
  1. #1
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    200
    Thanks Thanks Given
    7
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    So I was super careful in fitting the speedo angle drive to the OD, remembering the copper washer. The problem is that the female end of the angle drive is a 1/8 round hole and the speedo cable is a 3/32 square cable, so there is absolutely no engagement. Defective albeit new angle drive? The OD spins the angle drive perfectly, but the cable of course doesnt spin.
    Jim
    TS44743LO
  2. #2
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    256
    Thanks Thanks Given
    2
    7
    Thanked in
    Re: OD angle drive engaging the speedo cable
    Why are you using an angle drive, I thought the TR3 didn't have one?
    Graham
    [SIGPIC][/SIGPIC]
  3. #3
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    200
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    Quote Originally Posted by Graham H View Post
    Graham
    I thought Id need one with the OD... will try to run it without it, though.
  4. #4
    Join Date
    Feb 2018
    Location
    Posts
    256
    Thanks Thanks Given
    2
    7
    Thanked in
    I think you will find it all lines up nicely without the angle drive.
    Graham
    [SIGPIC][/SIGPIC]
  5. #5
    Great Pumpkin TR3driver's Avatar
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,486
    Thanks Thanks Given
    8
    135
    Thanked in
    Right, no angle drive needed for TR2-4. But you do need an extra-long speedo cable. 96" IIRC Angle drive is needed for TR4A-TR6 (and Stag, etc.)
    The hole should be square inside, to grip the end of the inner cable. Sometimes you can't see the square portion, but it should be there. Sounds like you got a bad angle drive.
    Angle drive should work, even on a TR3, but I much prefer the long cable. Less expensive and less troublesome.
    Randall
    56 TR3 TS13571L once and future daily driver
    71 Stag LE1473L waiting engine rebuild
    71-72-73 Stag LE2013LBW waiting OD gearbox rebuild
  6. #6
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    200
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    Quote Originally Posted by TR3driver View Post
    Thanks, guys. I already have the 96 cable, so sounds like overkill. Will run it tonight (these pesky day jobs...)
  7. #7
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    200
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    Quote Originally Posted by Jim_Stevens View Post
    As I was writing this, I figured out it is supposed to be routed it into the handbrake hole correct? Jim
  8. #8
    Join Date
    Feb 2018
    Location
    Posts
    256
    Thanks Thanks Given
    2
    7
    Thanked in
    Correct Jim, then follow the foot brake fluid pipe forward through the same large grommet up the fire wall and back into the back of the speedo through the grommet to the left of the battery box.
    Graham
    [SIGPIC][/SIGPIC]
  9. #9
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,913
    Thanks Thanks Given
    14
    50
    Thanked in
    I had the same questions a few weeks ago.
    My route for the cable.
    David
    TR3A TS75524L
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
