General TR The RT story video.
GilsTR
David. I have one that looks very much like the photo Healey Rick supplied.
fixes right to the stansion. Extremely helpful!
Gil. NoCal
DavidApp
Hello Rick and Gil
At the moment I am using a mirror that clamps to the SS piece between the stanchion and Wind shield frame and find the view very good with that setup. I am trying to make a change so I can have the same mirror setup with the side screens on the car.
Have been looking for the Harley Davidson ones.
David
Leatherman
I bought one at Carlisle. I like it so much I am eliminating the fender mounted one in my restoration. Only thing to consider they are not side screen friendly. You need to carry an Allen wrench to remove them if needed.
DavidApp
I have bought some chrome button head screws to anchor a bracket to the rearmost wind screen stanchion mounting bolt. Am trying to get a bracket nmade that I like the looks of and that works to hold the mirror at a convenient height.
David
Graham H
I think I have put my mirror up before, it mounts in one of the stanchion screw holes and is out of the way of the side screen. They were made by a TR Register Australia member bu I see his add in the for sale section has been taken down so I guess he no longer makes them.
Graham
ckeithjordan
I've never like fender mounted mirrors, so I searched for alternatives and found something similar to the Bugeye part. My 1957 TR3 has the Dzus-style stanchion attachment to the scuttle. I removed the windshield as well as the rearmost Dzus on the driver's side. I then removed the stanchion plate and removed the wire on the back side, which the Dzus fitting would have locked to. Using the stanchion plate as a guide, I drilled a 1/4 inch pilot hole in the inner plate (through the slot in the scuttle), then reamed that hole to 3/4 inch diameter in order to pass through a bolt.
I had previously located a vintage Wingard mirror on eBay (era appropriate), which is threaded at the base for a 5/16 x 24 x 1 bolt. I reattached the stanchion plate to the scuttle and mounted the windshield, locking it in place with the three remaining Dzus-fittings. Feeding the stainless bolt through with washer and lock washer, I place another stainless washer in the empty recess where the Dzus would have been (it fit!), I then placed a thin, rubber washer (which was trimmed to the diameter of the mirror's stem base) over the bolt, and threaded the bolt into the base of the stem. I used a socket driver to tighten the bolt to the stem once the mirror was correctly positioned. I then adjusted the mirror while sitting in the car.
The first photo shows a TR2 where the idea came from, the second and third photos show the installation on my car. It looks like it was a factory-fit.
DavidApp
Thank you.
My TR has the bolted stanchions co they are already threaded for 5/16 x 24 but I am not sure how long the bolt would need to be to catch the captive nut.
I will look for Wingard mirrors on the net.
David
martx-5
I tried a couple of different mirrors, including the Harley-Davidson type, but I wound up modifying one of the regular fender mirrors. For the driver's side, you need the passenger side wing mirror. There's a stud on the bottom that has the correct threads, but it is too short. The stud is cast in, so I cut it off and drilled and tapped for a longer stud. A couple of washers to fill in the recess in the stanchion, and it screws right in.
DavidApp
Hello Art
A neat solution. I will have to check into that avenue.
I have bent up some thicker Stainless steel to see how it will function. My last effort was a bit too thin so the mirror vibrated.
David
Graham H
That is probably as good as anything David, as you are never likely to take it off maybe drill a small hole and tape a screw into the stanchion just to stop it rotating down. I think you are onto a winner with that one, well done.
Graham
DavidApp
Hello Graham
Thank you. I had the Stainless steel laying around at home.
I put washers under the bracket to fill in the counter bore so the bracket is clamped down very tightly. The socket head screw allows a good amount or torque on the screw .
David
Tim Tucker "Triumph Story" video Triumph 2
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
JPSmit Interesting back story Other British Cars 0
R 2003 Discovery restoration story Rover / Land Rover 11
CLEAH My Healey Story, 40 Years On Austin Healey 13
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
AngliaGT TR2/3/3A Cool TR3 Baja Racer Story Triumph 5
HealeyRick Sad Story Austin Healey 21
R Healey Marque Brake Servo story Austin Healey 6
HealeyRick Another Owner's Story Austin Healey 4
CJD General Tech The Story of New Drivers Triumph 12
HealeyRick A Great Healey Reunion Story Austin Healey 8
S Sprite Story Spridgets 11
HealeyRick A Healey STORY [pun intended] Austin Healey 1
3798j 1957 Series 1 [A Love Story] Rover / Land Rover 2
HealeyRick Another 100M Story Austin Healey 23
catfood Restoration Story - BN1/225574 Austin Healey 22
HealeyRick Original Owner Story Austin Healey 1
germanmichel Horror story what I found below the battery... Austin Healey 9
M Off Topic Great TR3 story in Moss Motoring Triumph 12
J Cool story on a Healey Austin Healey 1
oxford the story so far Austin Healey 5
HealeyRick The BMC Story Spridgets 7
HealeyRick The BMC Story Austin Healey 29
Jer Spridget Detour - Wife's Dream Car Story Spridgets 14
tr6nitjulius Story & pic of Barn Find fate! Triumph 3
dougie Healey Racer on Bat - The Rest of the Story Austin Healey 5
5 British Motor Corporation Story Austin Healey 3
RickB Saw this success story on BAT Spridgets 4
Simon TR4a Just a 100/4 story which may interest you. Austin Healey 3
John Turney September Healey Marque - The Wife's Story Austin Healey 6
A TR2/3/3A Hilarious TR-3A headlight rim story Triumph 2
R Long story. Garage find 73 midget MG 0
R Long story. Garage find 73 midget Spridgets 50
JPSmit Sweet BAT Sprite story Spridgets 6
pkmh A Small Interesting Healey Story in the Naked City Austin Healey 11
S Truth or story? Austin Healey 47
G TR2/3/3A Rest of the story on stolen TR3 Triumph 4
E Saab story Other Cars 16
pipercollins Spitfire Spitfire Ignition Wiring - Story with followup ?'s Triumph 14
N BJ8 Oil consumption story Austin Healey 6
C The Story of a Very Special Jaguar Racecar Jaguar 2
V Great '69 Norton Story British Motorbikes 9
John_Mc Everyone has a story.... Triumph 20
DART SAAB story Other Cars 7
aeronca65t Nice Sprite Story Spridgets 5
C A "Healey people" story Austin Healey 1
germanmichel The story of the bad weld seams with MAG-welding.. Restoration & Tools 4
aeronca65t Nice E-type story Jaguar 3
tweety US auto industry, British Auto Industry, NPR story Spridgets 10
