MGB Battery relocation ponderings and considerations [and ideas?]....
YakkoWarner
I am SLOWLY getting closer to the light at the end of the tunnel on the seemingly perpetual metal work on the MGB body, to the point where I can at least spare a little mental bandwidth for contemplating next steps.
This is one of the years that used the dual 6 volt batteries. Wedging even the smallest 12 volt battery into one of the 6 volt wells looks iffy at best (unless I goto a motorcycle battery or larger lawn tractor/mower battery). And I'd like to have the battery in a more protected location where there is room for a protective box and such. Logically speaking the trunk is the next best bet, but that brings up its own questions in terms of mounting, cable routing and venting. I have been informally told that AGM batteries (like the Optima ones) don't need venting, but I can't get any form of definitive yes/no on that.
I'd like to repurpose the existing 6V wells for speaker boxes (since I absolutely HATE when people cut through the trunk bulkhead to install speakers and this body has not been chopped up in any way like that) which makes relocating the battery attractive as well.
So - any of the more well-experienced folks who have done (or decided not to do) this, I'd like some insights and info to know if it can be done properly, and if so how.....
Rut
My 1970 might be different, but I installed the boxes from Clark and Clark and fit a battery in the passenger side. It’s tight, but I used a common size battery and it fit.
Rut
Platinum
A "26" or "26R" battery fits the 6-volt well snugly, but it fits. As for radio speakers, there's room under-dash to fit a couple small speakers without cutting holes in the body. There are some amazing speakers available.
The caveat to my answer is: I'm less interested in listening to a sound system than I am listening to the engine and other audio "clues" coming from the cars. Our MGB is an early car (steel dash) and I fabricated a center console in place of the single speaker under-dash. Concession to sound system is as described above, a "modern" Panasonic AM/FM/CD player with small speakers.
MGBGM1977
Here is where I put mine. AGM battery out of my 1984 Goldwing.
BM Part #: YTX24HL-BS
Voltage: 12 Volt
Capacity: 21 Ah
Type: AGM
Length: 8.13"
Width: 3.44"
Height: 6.38"
Cold Cranking Amps: 350 CCA
Shipping Weight: 18.00Lbs
Y
YakkoWarner
Voltage: 12 Volt
Capacity: 21 Ah
Type: AGM
Length: 8.13"
Width: 3.44"
Height: 6.38"
Now thats an idea I have NOT seen before....I presume since its only 18 pounds it doesn't adversely impact that balance of the car being all the way up at the bumper. Have you experienced any downsides to using a battery with that low of an AH rating? The 350CCA will be more than enough to spin the motor but if it doesn't fire up immediately is there enough for several tries?
MGBGM1977
I have seen where many use the Miata battery. Many of those are rated the same or slightly higher. As my car starts very well, I have not had any problems at all so far. Had it in there about a year now.
Bob Branson
As for the trunk location, big Healeys had that, and many years ago I lost my 100-6 when the side curtains shorted across the terminals and caused a fire...right over the fuel tank.
T TR4/4A TR4 battery box relocation kit Triumph 4
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
RAC68 Battery Powerline Protection Austin Healey 40
