Results 1 to 4 of 4
Thread: extra hole in my water pump?
  1. #1
    Join Date
    Mar 2016
    Location
    cincinnati, ohio
    Posts
    31
    Thanks Thanks Given
    7
    Thanks Thanks Received
    Thanked in
    Hi Folks.. Got a new water pump and it seems there is an extra hole drilled. Installed there is one at the 6 o'clock. OK, a weep hole. There is also one at the 1:30 position. What is that one for? Excuse me if this has been answered before.
  2. #2
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    17
    Thanked in
    Re: extra hole in my water pump?
    The original pump had one slot at about an inch long at the bottom. There was also a grease fitting, 1/8 pipe thread at the top and aft of the slot.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  3. #3
    Join Date
    Mar 2016
    Location
    cincinnati, ohio
    Posts
    31
    Thanks Thanks Given
    7
    Thanked in
    Right, Tom. I have the original pump I think.. No grease fitting, but with the 1 inch slot. This car sat for 20 years..it's locked up. I bought a new one from TRF. There is about a 3/16 hole drilled in the casting at the bottom at the impeller end. I'm told that is a weep hole. OK, that makes sense. But there is an identical hole in the casting at about the 1:30 position..looking at the pump installed. Don't know what that is. Thought it might be an oil hole, like motors had in the old days. Thought it might be a mistake..you know..oops, that's wrong..I'll just drill another. Thought it might be a vent..don't know about that. Seems like oil and other assorted engine crud would get in and plug it. So, is it a mistake..should I fill it with something..or is it supposed to be there?
  4. #4
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,759
    Thanks Thanks Given
    9
    17
    Thanked in
    As long as both holes are in the same cavity, outside of the seal and bearing, it shouldn't matter and need not be plugged. Anywhere else would be a problem. Perhaps someone else has had the issue and will reply.
    Tom
  5. The Following User Says Thank You to TomMull For This Useful Post:
    deuce (02-05-2020)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
