TR2/3/3A Speed O not working
sp53
When I took the car out this time for a few laps around the block, I hooked the speed O-- but no reading on the gauge. I unhooked the cable and the cable was not turning. The trans is an OD with a new longer cable I purchased from TRF. Kinda looking for a starting point and any information about OD hook ups if they are different on the trans. Hopefully, I can leave the transmission in place. Perhaps the cable is not long enough, but that does not sound correct. All ideas welcome
TR3driver
Great Pumpkin - R.I.P
The connection is only different in that it's in a different location. I'd probably start by making sure the new inner cable protrudes from the outer cable far enough to engage the drive gear on the overdrive. Turn the drive end, and check that the speedo end turns.
If that all looks OK, next step is to pull the speedo pinion and bushing out of the OD. I'm pretty sure it can be done with the OD still in the car (but haven't tried it myself). There's a retaining bolt that comes out, then it's advisable to use the knurled collar from an old cable (either speedo or tach will work) to protect the threads and provide a place to pry the bushing out. (Photo courtesy Buckeye Triumphs)
DavidApp
Do you have the angle drive on the OD box? Also the washer that goes between the angle drive and OD?
David
S
sp53
Thanks Randall I will get a look in the morning. No David, I used the 96 inch cable and used a big loop and come through the shifting tunnel at the rubber boot bump. I think that is what the bump in the rubber boot is for by the E brake, but I have never installed an OD before.
TR3driver
That's right, on a TR3 (and TR4 IIRC), an extra-long cable is used so it can curve around and come up through the RH floorboard in the opening behind the handbrake. The handbrake boot has a passage for the cable.
DavidApp
So I do not need to use the angle drive. I did get the extra long cable. I do see on the documentation where it says TR's 63 on.
David
TR3driver
David
I checked, according to the factory catalogs, the angle drive wasn't used on TR4, introduced on TR4A (when they moved the handbrake location and eliminated the holes where the old cable ran). On the 4A with the angle drive, the longer cable is not required.
S
sp53
I went and undid the cable at the trans then turn the cable by hand to make sure it was in one piece and it was. Next I took an old cable put that in the trans and was able to spin the cable by hand. That does not sound correct. I am not sure how much should be sticking out of my new cable, but again I could turn the trans end by hand, so not sure.
It has been over 20 years since I have rebuilt a non-OD and I cannot remember exactly how the speedos were driven. I will have to pull the tunnel cover to access the speedo bearing assembly and hopefully the problem is in that if I can get it out. I do have some old speedo drives from non- OD trans and hopefully I can come up with something.
TR3driver
Pretty simple; there is a worm gear cut into the output shaft (which for an overdrive is one piece with the annulus).
Then the bushing carries a shaft & gear that meshes with the gear on the output shaft.
I forget the tooth counts offhand, but the worm is multi-start. The effective ratio is 5:2, meaning the speedo cable should turn twice for every 5 turns of the drive shaft.
Later on, with the J-type, the worm became a separate gear and the ratio could be changed. But for an A-type, it's always 5:2 (or 2.5:1 if you prefer).
S
sp53
So then what I am hearing the J type OD is totally different than a non-OD trans, and moreover I should not be able to turn the drive in the trans my hand?
I think remember there being like a shear pin in the drive assembly also?
TR3driver
Yeah, pretty much. Principles are the same, of course, but the parts are different; ratios too. Are you working on a J-type?
Speedo drive is geared directly to output shaft; should be impossible to turn the drive unless the output shaft turns as well.
I don't recall a shear pin, but it might be there. If something breaks, it's usually the teeth on the driven gear.
DavidApp
How does the longer cable get routed? I see it goes between the frame and floor by the loop in the brake line going to the rear axle.
David
S
sp53
I dug out a non-OD setup and they measure and look the same as OD—But the one in the car will not give any. There is a way to remove the inner brass section from the outer with flat side on the outer edge, but again I am not sure that will help any. Perhaps some kind of pulling tool would fit in there. I put a small amount of WD in the hole where the bolt came out on the top of case and I am waiting for that to work. Plus I was able to get some leverage by using the aluminum end piece and pry against that-- but no joy. There must be another way with some kind of specialty tool. Where is Geo he has all the cool pics of cool tools. I have been tapping lightly with some wood trying to cause some vibration. I hope one of those rebuilder guys might have a gear he would give up, but heck it might worse inside. I guess I should have tried to rebuild the OD in the beginning, but I was overwhelmed with learning body work
S
sp53
Well I killed the brass end on it, but I pray a non-OD is the same. My thoughts are aluminum oxidized to brass. Anyways I do have the bushing turning left to right about a ÂĽ turn, but it will not head out of the casing. Plus there is no way to get any oil between the case and the bushing and the bushing is a few inches long into the case. Any ideas out there? I am afraid to heat the brass because I do not know if it would do more harm than good. I guess keep trying to work it out left to right and cry for help.
CJD
That is common for the assembly to get stuck. If you have already damaged it, then just use big vice grips and twist it out. It does have a lock bolt in the tranny, so make sure that is removed first, or it’ll never come out. Don’t feel bad...some of those are so stuck they will never come out without damaging them. I am sure it is galvanic action with the aluminum, as you suggested.
There is an inner and outer sleeve to the brass assembly. If you look closely, there is a pin drilled and driven through to hold the 2 together, though. Before you can separate them, the pin must be drilled or it will damage the soft brass threads. Inside there is a seal that you can replace, if you want to.
I find it interesting that the assembly would strip. It is normally pretty stout.
You are in luck, in that the assembly is common throughout the TR2/3 range of trannies, with and w/o the OD.
S
sp53
Thanks John I truly appreciate that a lot. The square drive at the end was damaged and broken off at the very end--- somehow, and I believe it was blown out from an old broken cable, but I do not know. That is what accelerated my efforts to remove the assembly. I used a slim 5/8 wrench on the end bushings and separated the two brass pieces at the end and saw the damage to the tip-- then I put the aluminum end on and pinched that between the brass and 5/8 wrench then smacked it with a big screw driver down low, but it cracked the brass at the end.
Anyways yes I have gone to vise grips and got it to turn some. Probably 5 to 10 years ago, I would have twisted and turned with down pressure and get out more easily. Now I am going to use more leverage. One problem I see is because OD speedo assembly points down with really no way to get oil in there except if I had it apart-- maybe, but heck it is so oxidized and tight no oil might ever get in. Would you put heat to the brass if it was trashed or stay with muscling it out?
steve
DavidApp
Some spray penetrating oil may help as that will make its way in by capillary action.
Thought I had seen a fancy home made tool somewhere for getting that part out.
David
TR3driver
CJD
Heat is a tough call. Steel and aluminum have a big difference in expansion coefficients, but I think brass is pretty high like aluminum, so it may make less of a difference. But then, heat may soften the hardened grease to help. I might try it when all the other options are exhausted.
If you have gotten a bit of motion, using plenty of PB Blaster and working it back and forth should gradually free it up.
It always amazes me how the parts that seem so simple end up eating the most time...and that there are always more of those "simple" time consumers near the end of a restoration?!?
Z Wiper - Low Speed not Working Triumph 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
S Wedge 4-speed gearbox problem Triumph 6
