Results 1 to 5 of 5
Thread: 948 Cylinder Block Studs - Sequence on Cylinder Block
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Oct 2006
    Location
    Washington, DC
    Posts
    445
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    All:
    I have new replacement cylinder block studs (4 long and 5 short) for my 948. I need to understand where each sits / is situated on the block (prior to installing the head gasket and head
    Can someone advise? I can't find the info in the manuals.
    Thanks,
    MXP
  2. #2
    Jedi Warrior BlueMax's Avatar
    Join Date
    Dec 2010
    Location
    Easley, South Carolina
    Posts
    713
    Thanks Thanks Given
    Thanked in
    Re: 948 Cylinder Block Studs - Sequence on Cylinder Block
    Set your rocker shaft on the head In it's correct orientation and you will see how everything should go.
  3. #3
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    365
    Thanks Thanks Given
    7
    Thanked in
    the 4 long studs go through the rocker shaft the 5 short only through the head.
    Easy to see 4 on one side and 5 on other.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  4. #4
    Join Date
    Oct 2006
    Location
    Washington, DC
    Posts
    445
    Thanks Thanks Given
    Thanked in
    Thanks, guys. This was helpful. The head has been installed and torqued down.
    MXP
  5. #5
    Jedi Warrior SD Bugeye's Avatar
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    615
    Thanks Thanks Given
    3
    Thanked in
    Glad you changed them
    I swear they are made with some slightly harder than peanut butter
    amazing how much they stretch
    Door handles,Bootlid,Glovebox all fads
    59 sprite
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
