BN1 Soft Top installation - need advice!
CharlesBN1
hello all, I bought a new Robbins soft top for my '54 BN1 and I'm having a heck of a time trying to figure out how the front top bow (angle iron/wood) should be wrapped with the vinyl sent with the Robbins top. Two of the attached pictures show the top frame with the wood attached to the front bow; the other three pictures show the vinyl that is supposed to be wrapped around the iron/wood front bow. What I can't figure out is what the flap sewn to the vinyl is used for - the flap is approx 1 inch wide and it spans across the length of the bow. I'm tempted to just remove it, but surely Robbins put there for some reason. Has anyone on this forum with a BN1/BN2 installed a Robbins top? if so, can you offer some insight as to what that 1 inch-wide flap is for? I'd sure appreciate some advice or a picture or two showing how you wrapped the front bow on your top frame.
thanks in advance, Charles
Michael Oritt
Charles--
Many years ago Doug Reid and I installed a new Robbins top on my BN1. I cannot now recall the specifics and what we wound up doing and unfortunately Doug is deceased, but I do remember that things did not make sense to us either and we wound up improvising the installation so that it worked. I wish I could be more helpful and perhaps Robbins is now a better resource for assistance than they were then. I can only suggest that you install it in a way that makes sense to you.
CharlesBN1
CharlesBN1
Thanks Michael. Talked to Kent Lacy yesterday about the flap on the bow wrap, my understanding was that
the flap was not on the original tops and was added by Robbins to drape over the weather strip joint.
Charles
gladhill1937
It was meant to give the front edge of the top where it meets the windshield a more finished detail look. It actually looks very nice although not original.
Kent
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
Healey Nut BN1 at Auction on eBay Austin Healey 4
Z BN1 Crown Wheel and Pinion Austin Healey 1
