Sump Installation
LarryK
I use the black on oil pans resistant to fuel and oil. Blue I use on intake manifolds and water pumps. But, black works there too. See which is more resistant to fluids and heat.
R Proper Aluminum Sump Installation Austin Healey 13
Westfield_XI Evacu-sump installation Spridgets 5
Westfield_XI Evacu-sump installation questions Spridgets 4
WHT Oil Sump Question For Dougie Austin Healey 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
Lin Oil sump sealant question Spridgets 0
Lin Oil sump torque value? Spridgets 3
Walter74 Oil sump AH spares Austin Healey 5
M Sump Plug Austin Healey 26
F Sump Gasket Question Austin Healey 15
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
Lin Oil sump gasket replacement Austin Healey 31
Healey Nut 3000 oil sump pans Austin Healey 16
Michael Oritt Strange debris found in sump Austin Healey 19
J TR6 Thrust washers in sump Triumph 4
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
Dudly Sump and timing cover gaskets Triumph 1
TomMull Sump pan with no baffle? Triumph 2
abarth69 Dry Sump BMC Engine Spridgets 3
T XK Engine Sump Pan Jaguar 9
OZ_BN1 Sump Plug Austin Healey 0
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
newmexTR3 TR 2/3/4 aluminum sump gasket Triumph 4
B Oval sump washer orientation Austin Healey 2
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
2wrench Help. Leak from sump cover on bottom of J-OD Triumph 31
Scott_Hower MGB MGB sump removal .. must I drop the xmember? MG 13
J Can I drive with dipstick pipe in sump? Spridgets 6
philman Wedge TR8 oil sump pans Triumph 2
TRclassic3 TR2/3/3A TR3 Oil Sump Gasket Question Triumph 3
M XK 140 Sump color Jaguar 4
B Changing Oil - Can't Remove Sump Plug - Size? Austin Healey 11
cjm dry sump system Triumph 8
dkj313 MGB Sump Gasket 76 MGB MG 5
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
Lin Oil Sump gasket dressing [sealant] Austin Healey 3
Dave Russell Experience installing new oil sump Austin Healey 2
bighly Magnetic sump plugs / tranny plugs Austin Healey 0
P Oil sump capacity Austin Healey 7
bighly Sump [does 1 size fit all?] Austin Healey 1
A MGB Seat Cover Installation MG 1
Sarastro TR4/4A Convertible top installation problem Triumph 12
D BJ8 Top Installation Detail Austin Healey 3
zoohow BN4 Top Frame Installation Austin Healey 1
R MGB side chrome installation MG 4
P Alternator Installation Pic Austin Healey 4
