TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head?
TuffTR250
I have taken apart my steering wheel control head and replaced a couple of parts and greased with Dry Moly and white lithium grease. The turn signal lever moves real well on and off but will not self cancel with the cancelling ring. I have replaced the ring with one that has the slit in the top and has no wear at all. I even tried making the "dogs" longer by epoxying small pieces of aluminum to the flat ends of them. It still does not cancel even with those longer "dogs", but they rub even when the turn signal lever is not on. So I have gone back to the original "dogs". I've tried stretching the return springs by hand but that did not help. So I'm wondering if it would be possible to buy stronger/longer springs that push the return lever back to the off position. Not sure that would do the job, or create other problems. Does any one know where I might buy new stronger/longer springs to give it a try? Thanks!
charleyf
Bob,
It sounds like you are more into this than most of us ever get. But isn't the return action a function of the stem that fits down into the tube that goes down the steering column? If that portion of the control head is down into the tube and located properly with the knurled ridges into the slot, the turn signals should return to the neutral position. Do you have an adjustable steering column?
TR3driver
Great Pumpkin - R.I.P
Are you sure the canceling ring is being moved through the position where it forces the relevant "dog" back into the switch? The wheel has to turn far enough in the direction you are signalling for the dog to slide over the hump; then far enough back for the hump to force the dog into the switch.
A weak return spring might let the lever not return all the way, but I can't see it not moving at all. If it doesn't move at all, I think there must be something else wrong. And stronger springs would probably keep it from latching into the "on" positions (which happens to me sometimes even with original springs).
sp53
I put those little beveled shape pieces in backwards before. If I remember, they are kinda counterintuitive.
CJD
When I rebuilt mine I had an old trafficator from a TR3A, the original TR2, A purchased Ebay one, and one that came on a telescoping wheel From Marv. Four total. I used the new repro one, and it only cancelled to the left. After R&R’ing it 4 times, I finally realized some of the plastic never fully populated the mold, so a portion of the cancel mechanism was forever unserviceable. I then went through the 3 others, which all had great parts, but were too sun baked to re-use, looking for a replacement piece.
I found that not a single pair used the same exact parts. I had to purchase a 5th unit, which is still working great 3 years running.
What I am trying to get at is that there have been many, many, many small variations to the mechanism over the TR production run. If you are mixing and matching, it may be more complicated than just a spring rate.
John_Koop
I second the comment about the beveled shape pieces might be in backwards.
They should both have their pointed sides face down and their long side edges facing to the outside
TR3driver
John_Koop
In the picture of the control head, it look like the center spring does not put enough pressure on the little metal roller to make the little dogs flex to make the signal lever return to center.
TR3driver
It's a little hard to see, but the roller is actually still caught in the groove that carries the dog; which is holding the lever in the turn position. When the canceling ring rotates a bit farther, and the tip of the dog is on the highest part of the cam, the dog will be forced higher so the roller won't be caught and the lever will move.
I didn't have enough hands to get a photo with it moving :smile:
pdplot
My TR6 cancels only one way depending on where the lever sits at the time. I can rotate it back and forth a bit. You know what? I hand cancel when necessary.
glemon
I had a Healey 100, basically the same mechanism (though the parts aren't interchangeable), I had it apart many many times, finally got it to reliably signal, never got it to reliably cancel. I am kind of OCD about everything working right on my cars, but eventually let that one go.
Jayplum
Some times with a 6 the 'bump' on the shaft is not aligned well or the switch and stalk are not fitted tight.
54ragtop
Just a thought if this is still a problem. If the spring does not fully compress in either direction when operating. What about just adding an additional washer or two to each end?
T
TuffTR250
I finally did get it working correctly. Mine only had washers at the top of the springs. I added some at the bottom as well. Thanks!
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
V possible buy TVR 14
T 100 BN2 Possible Ignition Issue Austin Healey 7
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
