Results 1 to 15 of 15
Thread: Is it possible to buy stronger springs for turn signal lever in control head?
  1. #1
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    660
    Thanks Thanks Given
    Thanks Thanks Received
    3
    Thanked in
    I have taken apart my steering wheel control head and replaced a couple of parts and greased with Dry Moly and white lithium grease. The turn signal lever moves real well on and off but will not self cancel with the cancelling ring. I have replaced the ring with one that has the slit in the top and has no wear at all. I even tried making the "dogs" longer by epoxying small pieces of aluminum to the flat ends of them. It still does not cancel even with those longer "dogs", but they rub even when the turn signal lever is not on. So I have gone back to the original "dogs". I've tried stretching the return springs by hand but that did not help. So I'm wondering if it would be possible to buy stronger/longer springs that push the return lever back to the off position. Not sure that would do the job, or create other problems. Does any one know where I might buy new stronger/longer springs to give it a try? Thanks!
  2. #2
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,035
    Thanks Thanks Given
    1
    8
    Thanked in
    Re: Is it possible to buy stronger springs for turn signal lever in control head?
    Bob,
    It sounds like you are more into this than most of us ever get. But isn't the return action a function of the stem that fits down into the tube that goes down the steering column? If that portion of the control head is down into the tube and located properly with the knurled ridges into the slot, the turn signals should return to the neutral position. Do you have an adjustable steering column?
    Charley
    1962 TR4
    1963 TR4
    1959 TR3A A work in progress.
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,420
    Thanks Thanks Given
    8
    122
    Thanked in
    Are you sure the canceling ring is being moved through the position where it forces the relevant "dog" back into the switch? The wheel has to turn far enough in the direction you are signalling for the dog to slide over the hump; then far enough back for the hump to force the dog into the switch.
    A weak return spring might let the lever not return all the way, but I can't see it not moving at all. If it doesn't move at all, I think there must be something else wrong. And stronger springs would probably keep it from latching into the "on" positions (which happens to me sometimes even with original springs).
    Randall
  4. #4
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,345
    Thanks Thanks Given
    29
    Thanked in
    I put those little beveled shape pieces in backwards before. If I remember, they are kinda counterintuitive.
  5. #5
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,390
    Thanks Thanks Given
    6
    39
    Thanked in
    When I rebuilt mine I had an old trafficator from a TR3A, the original TR2, A purchased Ebay one, and one that came on a telescoping wheel From Marv. Four total. I used the new repro one, and it only cancelled to the left. After R&R’ing it 4 times, I finally realized some of the plastic never fully populated the mold, so a portion of the cancel mechanism was forever unserviceable. I then went through the 3 others, which all had great parts, but were too sun baked to re-use, looking for a replacement piece.
    I found that not a single pair used the same exact parts. I had to purchase a 5th unit, which is still working great 3 years running.
    What I am trying to get at is that there have been many, many, many small variations to the mechanism over the TR production run. If you are mixing and matching, it may be more complicated than just a spring rate.
    John
    1955 TR2
  6. #6
    Join Date
    Dec 2008
    Location
    LI NY USA
    Posts
    6
    Thanks Thanks Given
    Thanked in
    I second the comment about the beveled shape pieces might be in backwards.
    They should both have their pointed sides face down and their long side edges facing to the outside
  7. #7
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,420
    Thanks Thanks Given
    8
    122
    Thanked in
    Randall
  8. #8
    Join Date
    Dec 2008
    Location
    LI NY USA
    Posts
    6
    Thanks Thanks Given
    Thanked in
    In the picture of the control head, it look like the center spring does not put enough pressure on the little metal roller to make the little dogs flex to make the signal lever return to center.
  9. #9
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,420
    Thanks Thanks Given
    8
    122
    Thanked in
    It's a little hard to see, but the roller is actually still caught in the groove that carries the dog; which is holding the lever in the turn position. When the canceling ring rotates a bit farther, and the tip of the dog is on the highest part of the cam, the dog will be forced higher so the roller won't be caught and the lever will move.
    I didn't have enough hands to get a photo with it moving
    Randall
  10. #10
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    660
    Thanks Thanks Given
    3
    Thanked in
    Thanks for the responses! Sounds like it is not a good idea to change the lever springs.
  11. #11
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,353
    Thanks Thanks Given
    24
    Thanked in
    My TR6 cancels only one way depending on where the lever sits at the time. I can rotate it back and forth a bit. You know what? I hand cancel when necessary.
  12. #12
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,450
    Thanks Thanks Given
    14
    17
    Thanked in
    I had a Healey 100, basically the same mechanism (though the parts aren't interchangeable), I had it apart many many times, finally got it to reliably signal, never got it to reliably cancel. I am kind of OCD about everything working right on my cars, but eventually let that one go.
  13. #13
    Join Date
    Oct 2015
    Location
    Forest, Va
    Posts
    54
    Thanks Thanks Given
    Thanked in
    Some times with a 6 the 'bump' on the shaft is not aligned well or the switch and stalk are not fitted tight.
  14. #14
    Join Date
    Mar 2018
    Location
    Waterford,Pa.USA
    Posts
    3
    Thanks Thanks Given
    Thanked in
    Just a thought if this is still a problem. If the spring does not fully compress in either direction when operating. What about just adding an additional washer or two to each end?
  15. #15
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    660
    Thanks Thanks Given
    3
    Thanked in
    I finally did get it working correctly. Mine only had washers at the top of the springs. I added some at the bottom as well. Thanks!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
