Electric Relay Placement
Lin
Hi folks,
As a general rule, do you physically place electric relays closer to the controlling switch (dashboard) that operates a device (for example, fog lights or electric radiator fan) or closer to the device itself (front of car or radiator). Just curious if there is a general rule.
Thanks,
Lin
Michael Oritt
Re: Electrical question
Hi Lin--
There are probably several factors to take into account--space, appearance, etc--but since one of the advantages of using a relay is that it allows you to use lighter wire between it and the power source/switch (versus "hard wiring" the appliance) it would make sense to mount the relay as close as possible to what it is controlling.
Seeya in Crystal Springs.
vette
I agree with Michael. In my mind there are two reasons for the relay to be close to the device. 1. is that you do not want to have the high current or the larger wires coming into a small switch. the 2nd reason is that you want an efficient circuit so you should pull the larger wires the shortest and most direct route to the load device. Therefore the relay which is going to open and close those larger wires should be out there not pulled into an area such as the dashboard. An example of such a circuit is the starter solenoid. The large wires that have to run between the battery and the starter would be difficult to pull them into the dash area and also to attach them to the ignition switch. Therefore the location of the starter solenoid is near the starter itself and in a very direct path from the battery to the starter. The solenoid is simply a relay. The smaller wires are then pulled between the solenoid's coil and the ignition switch or a separate starter button.
steveg
I would counter that the production cars I've owned had the relays in a central location with the fuses, often in the passenger compartment.
It would be interesting to see an authoritative source on this question.
vette
You have a good point Steve. Many do have them centrally located. I usually do see them in an enclosure under the hood. My two Nissans have it that way. But of course that’s Nilsson. ��. Too me I think I would consider the size of the cables and the easiest routing.
vette
HealeyRick
Cool. And they could still be grouped with the mounting tab shown.
When I added relays for my headlights, I originally placed them out of the engine compartment inside the fenderwell near the headlights. Didn't take too long before they got wet and failed. These solved the problem.
In my BJ8 there is a open area (like a box) on the inboard side of the firewall that was empty having no purpose. It was large enough to hide a second Lucas dual fuse box and 3 relays mounted on a metal plate.
Guffy60
Many rally cars have them centrally located also, more fir the reason of easy / quick replacement than where they are best in the flow of electricity.
i am sure this will be similar for car manufacturers
plus most are inside the car so more protected from the elements.
RAC68
Hi All,
Steve, yes, many manufacturers have centralized protection centers for fuses, relays, and diagnostic computer plugins and, due to their electronic complexity, were designed that way. Our Healey harnesses were not and operating amperage for all devices are carried and controlled with elements directly wired into each circuit (i.e. Headlight Circuit, etc.).
Although this was not as much of an issue with few attached devices of low draw, many of us have added many more devices that have dramatically increased the amperage draw through circuit wiring. With aging, corrosion, and hardening, additional resistance results in increases in even the original equipment amperage draw with harnesses required to carry more power flow. Adding upgrades and add-ons through the same harnesses have caused many to exacerbate the situation with the switch from their original 23-amp generators for a 65+ alternators in order to meet the power demand.
So, what are you trying to protect? If you are installing relays to reduce the amperage flow through your harness from operational draw to that of switching only, I would suggest you place the relays closer to the device and create a harness to the nearest source of high power (i.e. generator/alternator). As with fuses, if you want to protect the circuit, place the fuse at the power source of the circuit but if your intention is to protect the device, place the fuse close to the device. Keep in mind that, in most cases the Healey's circuits and devices are not fuse protected and running additional wire to a central point only extends the circuit for questionable access convenience. Also, with a fuse block, you are limited what it provides. However, you can centralize critical components and compliment with the use of in-line fuse protection on all other circuits and components you wish to also protect. Although this combined approach will eliminate any limitations, it does require the creation of additional documentation that references the circuit and its location of fuse protection to ease future location.
Since all my relay and fuse connections are lubricated with dielectric grease and weather tight to eliminate moisture penetration over the substantial extended time of forgotten attendance, I trust the small benefit derived from a central fuse box and/or relay box is far less then the accepted limits.
Just my thoughts,
Ray(64BJ8P1)
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
T ?Changing BE to SU electric fuel pump Spridgets 8
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
KVH TR4/4A Electric Overdrive Lever Switch Triumph 3
mgedit TR2/3/3A Electric Powered TR3 Triumph 8
O Electric choke problem. Jaguar 0
T TR2/3/3A Location for electric fuel pump? Triumph 21
