TR2/3/3A Datsun 240Z aluminumn brake drums?
karls59tr
Is it true they will fit the rear Tr3 brakes? Is there an easy way to tell how much material is left on a used drum other than just eyeballing it?
Deleted member 8987
A lot of that Japanese stuff (early) is basically a knock-off of LBC stuff. No way to really eyeball drum and rotor thickness. I did that kind of work in shops......and decades worth, yeah, I can tell when a 1946 Lincoln drum is paper thin, but you need to check the max od specs and use a drum micrometer.Nominal diameter is 228.6 mm or 9 inches. Max is 230 mm or 9.055". Larger 9" alloy drum are used on all S30 models (1971-1978 Fairlady/240Z/260Z/280Z).
TR3driver
Great Pumpkin - R.I.P
They are not a direct fit, but can be modified to fit; provided you have the 9" rear drums (appx TS56377 and later). Center hole has to be enlarged, and IIRC the stud holes also have to be larger to fit a TR3. Some of the lip at the outer edge has to be removed as well; how much may depend on exactly which drums you get, and which TR3 brakes you have. The drums I got had two lips, and for the backing plates that were on TS39781LO (not originals), I had to remove most of both lips. Never did finish that project, the drums are still in the garage somewhere. So are the brakes for that matter, but the car is long gone.
glemon
If you want the aluminum make sure you check the specs of what you are getting, I looked into this and I think most of the aftermarket parts are cast iron, so you get the fins but not the weight savings.
Merlin63Tr4
I purchased finned aluminum drums for my TR4 from TRF some years back (P/N: HP 34), but they don’t seem to carry them anymore.
They are Brembo manufactured Datsun 240Z drums. TRF had them modified prior to sale since they fitted perfectly right out of the box.
Moss has finned aluminum drums (P/N 586-150), but they are for use on TR4A IRS -TR6. They mention that they could be fitted to earlier cars using 9” drums if the stud holes are enlarged.
M.
2 General TR TR6 VS Datsun 240Z Triumph 2
T Datsun TURBO 240Z.... Other Cars 14
C TR2/3/3A Datsun 240Z Drums on a TR3A Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
shadowfever Datsun 5-speed info neede Spridgets 5
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Bayless Started adapting the datsun gearbox today Spridgets 46
Marvin Gruber Datsun 2000 Other Cars 12
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
P Datsun 510 Other Cars 3
N Best lube for a Datsun gearbox?? Spridgets 6
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
jfarris Datsun 1200 Pickup in Alice Springs Spotted 0
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
T Pressure plate failure on BE with Datsun 5 speed Spridgets 8
histerical Datsun tranny help please Spridgets 18
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Rut Datsun 5 speed Spridgets 24
T Shifter Cupola for Datsun 5 speed Spridgets 19
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
T problems installing 1275/rivergate/datsun in BE Spridgets 25
bugedd Datsun 210 Trans Question Spridgets 9
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
T datsun 5 speed locking up - circlip problems?? Spridgets 0
PC Datsun roadster Spotted 0
abarth69 Innocenti C Datsun 5 speed install Spridgets 21
T Datsun 5 speed locked up Spridgets 7
RickB Datsun 210 with manual transmission $500 Spridgets 0
aeronca65t Datsun 2000 / SRL311 Spotted 3
RickB 65 Midget on craiglist Seattle - 'comes with datsun 5 speed' [nfi] Spridgets 12
RichBall Datsun shift levers on ebay Spridgets 0
C 1981 Datsun 210 for $900 Spridgets 6
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
AN5Sprite Another Datsun 5 speed for sale! Spridgets 8
RickB Fresh Datsun 5 speed and assiciated goodies Spridgets 15
