Sprite Petronix Electronic Ignition
Olivia0424
Hello all
I have a Sprite and ordered the positive earth electronic ignition for the 1275cc i have. The instructions said I needed non-solid spark plug wires. I'm unsure what that means. Could anyone please help by explaining or maybe providing a brand a model of the wires.
Thanks!
dklawson
They are saying to not use solid (wire) core spark plug wires. They want you to use resistor wires. Resistor wires typically have a center that looks like it is made up of a bunch of carbon fibers.
You should be able to get what you need from any of the usual vendors (BP Northwest, VB, Moss, TRF, etc). Just look for "resistor wires", not "solid core".
Boink
Bronze
I did the same conversion and it's worked out well... but I still carry the original dizzy in a toolkit in the car. :rolleye:
Pythias
Wise choice.. either that or carry a 2nd pertronix for when the first one fails.
I went to a CRANE unit over 10 years ago after my pertronix failed. I admit the failure to be my fault. I installed it in such a manner that the rotor rubbed the wires inside the dizzy and that caused the wire to break........ but it was a $250 tow bill. I have heard of other failures with the pertronix though, but NEVER once a CRANE failure. It is now the FAST XR700.
O
Olivia0424
Thank you all for the suggestions. This is the first time I rebuild an engine on my own. So far it has been a lot of fun and a great learning experience. Look forward to sharing some pics once its done.
Bayless
Not sure but give Moss a call on their 800 number and they can tell you.
dklawson
I have had a Crane failure.
I had the Crane/Alison ignition on the GT6 for years. I washed the engine bay one day. The remote amplifier got water in it and failed. You could say getting water in it was my fault but the amplifier was supposed to be potted to protect the electronics. The GT6 now has a Pertronix module.
The OP said he bought a Pertronix ignition, not a distributor. Therefore a complete spare distributor in the boot may not be an option. Carrying a spare Pertronix is obviously possible but expensive. For a lot less money you can carry a set of points and condenser in the boot. You can install those whenever necessary to get home.
There is one warning that should be mentioned to the OP since we are talking about ignition module failures. With the Pertronix installed, never leave the key in the RUN position with the engine NOT running. This can overheat the module causing it to fail. Pertronix has warned that with the engine not running, the time the key is left in RUN position should be limited to no more than 1 to 5 minutes (different techs have told people different time limits).
Regarding the Cobalt wires, the text at Moss describes these as "spiral core". Usually that means the wires reduce ignition system noise with inductance instead of resistance. That may not do what Pertronix wants your plug wires to do. I would call Pertronix and ask about them. I have NO experience with the plug wires linked below but they are resistor wires.
https://www.rockauto.com/en/moreinfo.php?pk=6530775&cc=1204872&jsn=331
Keep in mind that if you are using a right-angle distributor cap, almost any resistor wires you find will require you to remove the crimped on terminals and insert the wire end into the cap. Most plug wire sets these days are made for the "straight" caps.
Pythias
If I recall correctly I used Bosch plug wires. Some sets for VWs (bug) have right angle ends. ..
I found it's better to get a spare dizzy and set it up with points/condensor and carry that. Much easier to swap out a dizzy by the side of the road than to try to install and gap points.
YMMV
My 2¢
Boink
Bronze
Boink
Bronze
Definitely!
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
lbcspinners New article today from Hagerty Media: the Austin-Healey Sprite Austin Healey 0
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
B Bugeye Sprite Wiring Diagram Spridgets 1
C Seat Cover Bugeye Sprite Mark 1 Spridgets 5
