TR2/3/3A Timing chain tensioner.
DavidApp
I have the timing chain cover off my motor chasing down an oil leak. Think I have found that. It seems the aluminium plug in the oil gallery may not have been sealed properly. There was oil between the mounting plate and block in that area. Also the plug came out with very little effort.
When I was reassembling the motor I noticed there is some wear on the inside of the timing chain cover caused by the end of the chain tensioner spring. The end of the spring was digging into the cover.
I have ground a bit off the outer corner of the spring. Not sure if this wear is new or was there before I rebuilt the motor.
Ant ideas? I have thought of welding it up.
David
TomMull
Problem is that about all of the covers I've removed had the same issue so it seems likely that the tensioner will wear at it again. I would weld it. Grinding the spring seems a good idea and I'll try that on my next one.
Tom
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
B Timing chain tensioner help Austin Healey 15
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
Darrell_Walker Timing chain tensioner wear Triumph 8
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
H 100 Engine Timing Chain Tensioner Austin Healey 3
John Loftus Timing chain tensioner question Austin Healey 14
P Newbie Missing or Broken Timing Chain Tensioner? Triumph 11
michalotti_tr TRactor motor timing chain tensioner Triumph 7
A Timing chain tensioner---old or new?? Triumph 4
Y Timing chain tensioner spring Triumph 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
