TR2/3/3A Front Bumper Brackets
BobbyO
Are there any differences in the TR3A front bumper brackets? I purchased a pair of front bumper brackets from a member and they were exactly as advertised; no damage. After installation, the distance between bolt holes is 31" and the distance between the holes on the bumper is 32". There's no way to make the bumper fit. Also, there isn't any damage to the frame so that's ruled out. Any suggestions as to how to solve this problem? I'm at a loss. Is there anything else I should be looking at?
TR3driver
Great Pumpkin - R.I.P
I suspect you know this, but I'm going to say it anyway: On a 3A, the brackets that attach to the frame do not attach to the front bumper. Instead, the frame extensions come up to the holes in the front apron, and then there are two sub-brackets (one each side) that run from the apron to the bumper.
1" doesn't sound like much at all to me. That's only 1/2" per side, should be almost that much space in the (oversize holes). You should be able to bend the brackets enough to take up the remainder. Or if necessary, leave the bolts through the frame loose until the bolts into the bumper are in place, then tighten them down (to bend the brackets into the required shape).
B
BobbyO
Hadn't thought of bending the brackets; however, when I hold the bumper to the apron for equal spacing on both sides, the 1" is all on one side. If I leave the frame bolts loose until the bumper is in place it might result in all the bend occurring on only one side. I might give it a try though. Thanks
sp53
Yeah those things are fiddly sometimes. I would put a washer on the back bolt between the frame and bracket to bring it in or one on the front bolt between the frame and bracket to bring it out. You can purchase U shaped shims in different thicknesses and move them around to line up the holes also.
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 6
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
R TR2/3/3A TR-2 Front Bumper Brackets & Front and Rear Overriders Triumph 1
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
sjuengst Front bumper brackets: T vs Y? Austin Healey 8
S Front bumper brackets - BJ8 Austin Healey 2
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B MGA Front bumper solution!! MG 1
RickPA Mounting number plate on front bumper Austin Healey 4
T To use front bumper on Bugeye or not? Spridgets 29
M TR4/4A Front Bumper for TR4 Wanted. Triumph 3
M TR4/4A TR4A & 250 front bumper guards Triumph 5
J TR2/3/3A Having fun installing the front bumper and bumperetes Triumph 7
T TR2/3/3A TR3A front chrome bumper Triumph 14
M Front Bumper Nut size Spridgets 2
jackq MGB-GT New A side curtains and front bumper>>trade??? MG 4
S TR2/3/3A front bumper override tr3 Triumph 6
S TR2/3/3A front bumper on a tr3a Triumph 1
D ID this front bumper setup? Spridgets 5
newmexTR3 TR2/3/3A Opinions wanted- TR3 with no front bumper options Triumph 22
P holes in 76 midget 1500 front bumper Spridgets 6
J MGA MGA front bumper support dimensions MG 1
scoutll No Front Bumper - What do you think? Spridgets 40
Brooklands TR2/3/3A TR3B front bumper and turn signal woes. Triumph 18
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
1 60 BE front bumper or no front bumper... Spridgets 15
GBRandy Wedge TR8 Conv Front Bumper Triumph 8
c5racer B Front Air Dam on a Rubber Bumper Midget Spridgets 3
J TR6 Need front bumper for 1976 TR 6 Triumph 6
mrsprite Bugeye front bumper wanted Spridgets 19
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
Atrus front bumper mount removal Spridgets 2
M Split Front Bumper Triumph 1
I Bugeye front bumper Spridgets 9
Monark192 Front Bumper Spridgets 1
AUSMHLY split-front-bumper Austin Healey 9
PAUL161 Chrome front bumper mounting hole problem MG 8
Saff Front Bumper Overriders Triumph 0
rick_ingram MGB NOS Front Rubber Bumper - MGB MG 0
DrEntropy Finally got my front bumper! MG 53
drooartz Spitfire Possible to lower front bumper on Spitfire Mark 3? Triumph 2
R front rubber bumper replacement Spridgets 7
2 72 Front Bumper Triumph 1
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
