Results 1 to 14 of 14
Thread: BJ8 NGK Spark Plugs
  1. #1
    Darth Vader AUSMHLY's Avatar
    Join Date
    Jan 2005
    Location
    California
    Posts
    2,607
    Thanks Thanks Given
    Thanks Thanks Received
    7
    Thanked in
    BJ8 NGK Spark Plugs
    I believe most people choose Champion RN12YC or NGK BP6ES.
    I'm running Pertronix carbon wires, Pertronix ignitor, top load cap, Lucas sports coil.
    Currently using RN12YC gapped .032. (Those who have the same setup as I, do you gap at .025, .030, .035 ?)
    I'm thinking of trying the NGK BP6ES plugs.
    When doing a quick search, it seems there are two version of BP6ES...7333 and 4007. Which one should I run, and what's the difference?
    Also, what should I gap the NGK plugs?
    As always,
    Thank you in advance.
    1964 BJ8 phase II
  2. #2
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,906
    Thanks Thanks Given
    104
    167
    Thanked in
    Re: BJ8 NGK spark plug
    Checking NGK's site, evidently no difference. Both gapped at .031".
    Can't go wrong with NGK BP6ES.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #3
    Join Date
    Oct 2009
    Location
    Arizona
    Posts
    20
    Thanks Thanks Given
    Thanked in
    I believe the different part numbers on NGK's refer to a single plug or pack of 4 plugs. I have found that the BP6ES work very well and have good quality control.
  4. #4
    Luke Skywalker LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,922
    Thanks Thanks Given
    14
    Thanked in
    I used NGK in my GT6 and the shop I worked for used NGK. My main plugs are Champion, cheap and regular 2 yr warranty. The Champions are not a plug you can clean and reuse after flooding or after firing up rotted fuel. NGKs are better. Autolite can be cleaned and reused with regular use.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual ,
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  5. #5
    Join Date
    Jan 2005
    Location
    California
    Posts
    2,607
    Thanks Thanks Given
    7
    Thanked in
    4007, terminal type, solid
    7333, terminal type, removable nut
    1964 BJ8 phase II
  6. #6
    Join Date
    May 2017
    Location
    Gloucestershire England
    Posts
    139
    Thanks Thanks Given
    2
    Thanked in
    Probably a rookie question but why use anything other than the plug quoted in the Haynes manual - UN12Y gapped at 0.25? Also why can't you clean and re-use the UN12Y?
    I do realise that Petronix recommend increasing the gap but can't remember by how much.
    AJ
  7. #7
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,113
    Thanks Thanks Given
    5
    56
    Thanked in
    The only Champion I've seen in The Colonies is the RN12YC; the 'C' is for copper electrode, presumably to distinguish it from the exotic metal type prevalent today, and the 'R' is for resistor (about 15KOhms by my DVM). I've used them for years with nary an issue.
    I used to try to clean plugs--even bought one of the pneumatic/media tools--but heard somewhere that media blasting can remove the glaze on the ceramic insulator, possibly causing misfire. I don't know if this is an issue or even a thing, but for the price of plugs if you're going to remove them why not put in new? Plugs can easily go over 25K miles in a properly tuned engine.
    There are counterfeit plugs going around (notably on eBay): http://www.ngk-sparkplugs.jp/english...ake/index.html
    Note the 12YC cross-references to a BP5ES: https://www.sparkplug-crossreference...CHAMP_PN/UN12Y
  8. #8
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,509
    Thanks Thanks Given
    9
    39
    Thanked in
    The NGKs will clean themselves if they get fouled, like getting loaded up in stop-n-go traffic. After an Italian tune up, they fire as crisp as they ever did.
    Not so with Champions, I quit using them decades ago.
    Apparently this is still the case, as a complimentary Champion* bit the dust in my 2-stroke McCulloch go kart engine. As soon as I replaced it with my preferred NGK, the engine fired right off!
    * Champion plug provided to me by a fellow vintage karter at an event last year; carrying more spares now (will be interesting to see if I need them )
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Coupe EB w/ ES/TS & 99 M Rdstr BK/BK
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    16 X5M/DINAN Stg II Mineral White Metallic Wife's 716 hp/702 Lb-ft Turbo Hauler
  9. #9
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,113
    Thanks Thanks Given
    5
    56
    Thanked in
    Good to see you back!
  10. #10
    Join Date
    Feb 2003
    Location
    Posts
    4,509
    Thanks Thanks Given
    9
    39
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    Thanks Bob!
    I veered off topic in the "camber" thread, giving an update on physical condition, and suspicious of a decline in mental condition...
  11. #11
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,113
    Thanks Thanks Given
    5
    56
    Thanked in
    Quote Originally Posted by Randy Forbes View Post
    ... suspicious of a decline in mental condition...
    Don't worry, we're all declining at the same rate and ways; no one will notice
  12. The Following User Says Thank You to Bob_Spidell For This Useful Post:
    Randy Forbes (01-26-2020)
  13. #12
    Jedi Knight Rob Glasgow's Avatar
    Join Date
    Feb 2003
    Location
    Lompoc, CA
    Posts
    829
    Thanks Thanks Given
    4
    Thanked in
    Re: BJ8 NGK Spark Plugs
    Perhaps we should install NGK plugs in our brains since they "self clean" when fouled. My brain seems fouled a lot lately.
    Rob Glasgow
  14. #13
    Join Date
    Jan 2005
    Location
    California
    Posts
    2,607
    Thanks Thanks Given
    7
    Thanked in
    Anyone recommend using the NGK BPR6ES (7131) resistor version over the the non resistor NGK BP6ES (4007, 7333)?
    Example, I needed to run carbon spark plug wires because when I switched to negative ground my Smith electronic tach didn't work correctly with copper wire.
    I'm currently using Champion RN13YC, problem free. Thought I'd try the NGK out. Resistor or not?
    1964 BJ8 phase II
  15. #14
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,906
    Thanks Thanks Given
    104
    167
    Thanked in
    My understanding is you only need one resistor component. If you have the wires, you don't need the plugs.
    Steve Gerow
    Altadena, CA, USA
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
