Results 1 to 3 of 3
Thread: Early MGB engine compatible with later transmission
Discussions of MG Sports Cars
  1. #1
    Join Date
    Dec 2008
    Location
    AZ
    Posts
    1,670
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I'm new to MG's so please bare with me on this. I have a freshly rebuilt 4 synchro O/D side fill transmission with the closed bellhousing for the starter (no hole). I need to purchase an engine and found a 1965 5 bearing engine 18GB UH 5875 locally. This engine uses the starter that has the drive assembly that sticks out of the transmission tunnel. Will this engine be compatible with the O/D transmission that I have if I use one of the high torque starters and are there other complications that I need to worry about? Any concerns with the flywheel and ring gear, transmission input shaft and pilot bushing, bell housing mating up to the rear engine plate. Any help is greatly appreciated.
    Thanks
    Keith
    Keith D
    1974 TR6 been the owner of this car for 37 years.
    1956 TR3 car is being restored.
  2. #2
    Join Date
    Aug 2008
    Location
    monroe nc
    Posts
    1,014
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Early MGB engine compatible with later transmission
    To put the earlier GB series engine up to a full syncro trans the flywheel backplate and starter need to be the later style from 68 and newer. The pilot bush is the same .
  3. #3
    Join Date
    Dec 2008
    Location
    AZ
    Posts
    1,670
    Thanks Thanks Given
    Thanked in
    Thank you Bob for the information, I think I got this figured out.
    Keith D
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
