TR2/3/3A Clutch through out fork misaligned
DavidApp
I am about to install an OD transmission in my TR3A and to speed things up a bit as well as insuring everything was good in the clutch area I got a new clutch operating shaft and clutch operating fork.
I added the extra screw to help prevent the locking pin from shearing. When I try to fit the release bearing assembly with the locating bolt in the gear box casting I found that the fork is offset by 1.5mm so I can not
install the release bearing assembly.
I see my options as Call the place I got the parts.
Remove 1.5mm from one side of the fork.
Move the locating slot over 1.5mm.
Any other ideas?
David
CJD
Interesting. I have always had enough play that the fork will tap each side of the carrier as the rod slides back and forth. When you say “locating slot”, are you talking about the one for the fork or the one on the end of the shaft on the pax side? If it is the slot at the end of the shaft, then I consider that redundant anyway. I personally would have no problem leaving it out, as the fork will keep the rod centered.
DavidApp
Hello John
Yes I am referring to the bolt on the Pax side. I did wonder about the reason for it as the fork prevents the shaft from coming out. The spring on the clutch side would tend to bias the fork into the through out assembly.
I may leave the bolt out.
David
Sarastro
I don't see the regular locking pin in your photo. The extra screw (I used a taper pin) is in addition to the regular, square-headed pin, not in place of it, and the regular pin should locate the fork on the shaft. If you insert it, do you still have the problem?
DavidApp
I did use the square headed pin to locate the fork before I added the second screw. I had not install the screw that locates the shaft in the gearbox casting when I first installed the tapered square headed pin. When I went complete the assembly, everything tight and square pin wired I found I could not get the screw in the passenger side of the casting that locates the shaft.
I had removed the locating pin when the photo was taken as it is difficult to get the through out assembly off with it in place.
Still have the problem.
David
Graham H
David,
I have seen this problem on another Forum and from memory the problem was with the new shaft, either the taper pin or the locater slot is in the wrong place. Leaving the locater pin out shouldn't be a problem, I have a box out of a TR6 and it doesn't have the locater pin. With a locater pin the anti rattle spring would be of very little value so you are good to go without the pin.
Graham
CJD
David,
Graham
+1...I was going to mention that the outer locating bolt was later removed by Triumph.
Sarastro
I had a similar problem with a new shaft that I bought for my TR4A. When the locating/retaining bolt on the right side was installed, the fork wasn't centered. I suspected that the shaft was designed for a different car (TR6?) and there were minor differences in the later transmissions. But the error was greater than the 1.5 mm you are seeing; it was more like 5 mm, if I remember right.
That's why I suspected that the drilling for the new bolt might just be a little off. If the original pin were installed, that would tell you for sure if there is a problem with the shaft.
charleyf
David,
I encountered the same problem a few weeks ago using a TR6 tranny with a TR3 clutch setup. As John says the locating bolt on the pax side is the problem. I found that changing the bolt from the 5/16" to a 1/4" with a nut on the end gave me enough room to move the shaft and allow the TOB carrier to function on the input shaft cover. Interesting that it could also just be left off.
charleyf
Not a favorable result. The pin for the fork is offset ( not centered) and would therefore not allow even a close fit.
DavidApp
I am going to go with no retaining bolt on the Passengers side as it seems redundant any way.
Is there any issues with the grease coming out of the bolt hole if you fit the grease zerks?
David
Graham H
My 6 box doesn't have grease nipples for the clutch shaft, Triumph must have relied on oil leaks for lubrication?
Graham
sp53
Glad you are getting David; I will be following close because I have no experience with OD and one day I will get mine up and going and I can learn from you. I would think a proper amount of grease would help lube and help seal the area.
steve
charleyf
If you use a 1/4" bolt with a washer on each side of the tranny box and a nut you will effectively close off the hole and prevent grease getting out or dirt getting in.
DavidApp
I did the smaller diameter bolt.
Having contacted TRF about this problem Albert got back to me and said they were looking into it.
Great service from TRF.
Thank you.
David
T TR4/4A TR4A Through 6 Diaphragm Clutch Triumph 12
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
