Results 1 to 18 of 18
Thread: Clutch through out fork misaligned
  1. #1
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,816
    Thanks Thanks Given
    13
    Thanks Thanks Received
    45
    Thanked in
    I am about to install an OD transmission in my TR3A and to speed things up a bit as well as insuring everything was good in the clutch area I got a new clutch operating shaft and clutch operating fork.
    I added the extra screw to help prevent the locking pin from shearing. When I try to fit the release bearing assembly with the locating bolt in the gear box casting I found that the fork is offset by 1.5mm so I can not
    install the release bearing assembly.
    I see my options as Call the place I got the parts.
    Remove 1.5mm from one side of the fork.
    Move the locating slot over 1.5mm.
    Any other ideas?
    David
    TR3A TS75524L
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,390
    Thanks Thanks Given
    6
    39
    Thanked in
    Re: Clutch through out fork misaligned
    Interesting. I have always had enough play that the fork will tap each side of the carrier as the rod slides back and forth. When you say “locating slot”, are you talking about the one for the fork or the one on the end of the shaft on the pax side? If it is the slot at the end of the shaft, then I consider that redundant anyway. I personally would have no problem leaving it out, as the fork will keep the rod centered.
    John
    1955 TR2
  3. #3
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,816
    Thanks Thanks Given
    13
    45
    Thanked in
    Hello John
    Yes I am referring to the bolt on the Pax side. I did wonder about the reason for it as the fork prevents the shaft from coming out. The spring on the clutch side would tend to bias the fork into the through out assembly.
    I may leave the bolt out.
    David
    TR3A TS75524L
  4. #4
    Obi Wan Sarastro's Avatar
    Join Date
    Jul 2006
    Location
    Long Beach, California
    Posts
    2,348
    Thanks Thanks Given
    1
    8
    Thanked in
    I don't see the regular locking pin in your photo. The extra screw (I used a taper pin) is in addition to the regular, square-headed pin, not in place of it, and the regular pin should locate the fork on the shaft. If you insert it, do you still have the problem?
    Steve Maas
    1966 Triumph TR4A, undergoing restoration: http://www.nonlintec.com/tr4a
    1952 MG TD, restoration completed 2014, sold 2016: http://www.nonlintec.com/mgtd
    1960 Austin-Healey "Bugeye" Sprite, sold 2010: http://www.nonlintec.com/sprite
    1967 Porsche 912: http://www.nonlintec.com/porsche
  5. #5
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,816
    Thanks Thanks Given
    13
    45
    Thanked in
    I did use the square headed pin to locate the fork before I added the second screw. I had not install the screw that locates the shaft in the gearbox casting when I first installed the tapered square headed pin. When I went complete the assembly, everything tight and square pin wired I found I could not get the screw in the passenger side of the casting that locates the shaft.
    I had removed the locating pin when the photo was taken as it is difficult to get the through out assembly off with it in place.
    Still have the problem.
    David
    TR3A TS75524L
  6. #6
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    251
    Thanks Thanks Given
    2
    6
    Thanked in
    David,
    I have seen this problem on another Forum and from memory the problem was with the new shaft, either the taper pin or the locater slot is in the wrong place. Leaving the locater pin out shouldn't be a problem, I have a box out of a TR6 and it doesn't have the locater pin. With a locater pin the anti rattle spring would be of very little value so you are good to go without the pin.
    Graham
    [SIGPIC][/SIGPIC]
  7. #7
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,390
    Thanks Thanks Given
    6
    39
    Thanked in
    Quote Originally Posted by Graham H View Post
    David,
    Graham
    +1...I was going to mention that the outer locating bolt was later removed by Triumph.
    John
    1955 TR2
  8. #8
    Join Date
    Jul 2006
    Location
    Posts
    2,348
    Thanks Thanks Given
    1
    8
    Thanked in
    I had a similar problem with a new shaft that I bought for my TR4A. When the locating/retaining bolt on the right side was installed, the fork wasn't centered. I suspected that the shaft was designed for a different car (TR6?) and there were minor differences in the later transmissions. But the error was greater than the 1.5 mm you are seeing; it was more like 5 mm, if I remember right.
    That's why I suspected that the drilling for the new bolt might just be a little off. If the original pin were installed, that would tell you for sure if there is a problem with the shaft.
    Steve Maas
  9. #9
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,035
    Thanks Thanks Given
    1
    8
    Thanked in
    David,
    I encountered the same problem a few weeks ago using a TR6 tranny with a TR3 clutch setup. As John says the locating bolt on the pax side is the problem. I found that changing the bolt from the 5/16" to a 1/4" with a nut on the end gave me enough room to move the shaft and allow the TOB carrier to function on the input shaft cover. Interesting that it could also just be left off.
    Charley
    1962 TR4
    1963 TR4
    1959 TR3A A work in progress.
  10. #10
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,450
    Thanks Thanks Given
    14
    17
    Thanked in
    Is it possible to flip the shaft or the fork 180 and get a different result?
  11. #11
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,035
    Thanks Thanks Given
    1
    8
    Thanked in
    Not a favorable result. The pin for the fork is offset ( not centered) and would therefore not allow even a close fit.
    Charley
    1962 TR4
    1963 TR4
  12. #12
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,390
    Thanks Thanks Given
    6
    39
    Thanked in
    Quote Originally Posted by charleyf View Post
    ...and the lever would point up...or out the wrong side!?!
    John
    1955 TR2
  13. #13
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,816
    Thanks Thanks Given
    13
    45
    Thanked in
    I am going to go with no retaining bolt on the Passengers side as it seems redundant any way.
    Is there any issues with the grease coming out of the bolt hole if you fit the grease zerks?
    David
    TR3A TS75524L
  14. #14
    Join Date
    Feb 2018
    Location
    Posts
    251
    Thanks Thanks Given
    2
    6
    Thanked in
    My 6 box doesn't have grease nipples for the clutch shaft, Triumph must have relied on oil leaks for lubrication?
    Graham
    [SIGPIC][/SIGPIC]
  15. #15
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,345
    Thanks Thanks Given
    29
    Thanked in
    Glad you are getting David; I will be following close because I have no experience with OD and one day I will get mine up and going and I can learn from you. I would think a proper amount of grease would help lube and help seal the area.
    steve
  16. #16
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,035
    Thanks Thanks Given
    1
    8
    Thanked in
    If you use a 1/4" bolt with a washer on each side of the tranny box and a nut you will effectively close off the hole and prevent grease getting out or dirt getting in.
    Charley
    1962 TR4
    1963 TR4
  17. #17
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,816
    Thanks Thanks Given
    13
    45
    Thanked in
    Thank you.
    I like that idea. A smaller bolt and washers will defiantly work as a grease seal.
    David
    TR3A TS75524L
  18. #18
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,816
    Thanks Thanks Given
    13
    45
    Thanked in
    I did the smaller diameter bolt.
    Having contacted TRF about this problem Albert got back to me and said they were looking into it.
    Great service from TRF.
    Thank you.
    David
    TR3A TS75524L
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
