Results 1 to 12 of 12
Thread: Fuses Blowing
  1. #1
    Join Date
    Mar 2018
    Location
    Auckland NZ
    Posts
    25
    Blog Entries
    1
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Fuses Blowing
    Hi All,
    When I try to engage OD on my Healey 100 BN1 (with a BN2 gearbox), both the 50A AND the 35A below it, blow. Any ideas Why?
    Cheers,
    Wally Simpson
    Last edited by Editor_Reid; 01-15-2020 at 02:48 AM. Reason: No need to thank me. Just doing my job.
  2. #2
    Jedi Warrior BJ8Healeys's Avatar
    Join Date
    Dec 2001
    Location
    Havelock, NC USA
    Posts
    716
    Thanks Thanks Given
    3
    30
    Thanked in
    Re: fuses
    Quote Originally Posted by Walker sim View Post
    Hi All,
    Cheers,
    Wally Simpson
    Wally, it sounds like something is wired incorrectly. Normally, the overdrive is not fused but the pull-in coil in the overdrive solenoid draws a lot of current (about 24A) for a short period of time (until the holding coil is energized, then the current drops to about 1A.) I'm assuming the BN1 or BN2 overdrive wiring is the same as a BJ8. Perhaps the attachment will help you troubleshoot it.
    Good luck!
    Steve Byers
    HBJ8L/36666
    BJ8 Registry
    AHCA Delegate at Large
    Havelock, NC
  3. The Following User Says Thank You to BJ8Healeys For This Useful Post:
    Editor_Reid  (01-14-2020)
  4. #3
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,764
    Thanks Thanks Given
    16
    Thanked in
    Re: fuses
    Hi All,
    Cheers,
    Wally Simpson
    When did this problem surface ??
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  5. #4
    Join Date
    Mar 2018
    Location
    Auckland NZ
    Posts
    25
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: fuses
    Hi Keoke
    About two months ago, previously OD worked fine. I replaced both fuses, engaged OD & again, both fuses blew.
    Cheers,
    Wal
  6. #5
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,429
    Thanks Thanks Given
    11
    81
    Thanked in
    Re: fuses
    Hi Keoke
    Cheers,
    Wal
    Did you use the proper fuses: 'slow-blow,' with the proper rating (the English rating is different than the ones you can typically get at the local parts house)?
  7. #6
    Join Date
    Mar 2018
    Location
    Auckland NZ
    Posts
    25
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: fuses
    Quote Originally Posted by Bob_Spidell View Post
    Yes, What I can't understand, if there is a problem within the OD, why do both fuses blow at the same time. I obtained the 50A from "Element14" in Aussie. Voltage rating VAC250V (made in China on the packaging). I wonder if there is a fault in the fuse block.
    Cheers,
    Wally
  8. #7
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    4,347
    Thanks Thanks Given
    99
    86
    Thanked in
    Re: Fuses Blowing
    According to the Bill Young BN1 wiring diagram in the January 2019 Healey Marque, power for the OD comes from the fused side (terminal A4) of the 35-amp fuse (This is different than later Healeys). The 50-amp fuse should only go to the horns. The supply side wire to the fuses should be brown (terminals A1 & A3); the fused wire to the horns should be brown with a green stripe (terminal A2). The fused side wires from the 35-amp fuse should all be green (terminal A4).
    You could have a connection between terminals A4 and A2, causing power to the OD to go through both fuses. Check the fuse block for this. With a short in the OD circuit, the current is enough to blow both fuses, probably the 35-amp one first, then the 50-amp one.
    The next problem could be the OD solenoid or a wire in the OD circuit shorted to ground (earth). Anyone know the inrush current of the OD solenoid?
    John, BN4
  9. #8
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,372
    Thanks Thanks Given
    5
    24
    Thanked in
    Re: Fuses Blowing
    Divide and conquer ..... disconnect the wire to the solenoid . Install new fuses and with the OD solenoid wire taped off to prevent short . Turn on OD switch .... do the fuses blow , no connect solenoid with switch on , fuses , blow , yes , bad solenoid .
    Fuses blow with solenoid disconnected and wire taped off , short in wiring or fuse block . This is not complicated .
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnet Kingston 2013
  10. #9
    Join Date
    Mar 2018
    Location
    Auckland NZ
    Posts
    25
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: Fuses Blowing
    Quote Originally Posted by John Turney View Post
    Thanks John, I'll check the fuse block, strangely, with both fuses blown the horns still work but the wipers don't.
    The car was restored 30 odd years ago then placed in a collection with little use until I bought it. Maybe the correct color wires weren't used which could make it difficult, I'll check.
    Cheers,
    Wally
  11. #10
    Join Date
    Mar 2018
    Location
    Auckland NZ
    Posts
    25
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: Fuses Blowing
    Thanks Jedi, Sounds simple, I'll have a go
    Cheers, Wally
  12. #11
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,970
    Thanks Thanks Given
    1
    22
    Thanked in
    Re: Fuses Blowing
    I think maybe some wires at the fuse block got switched around. The horn should be on the fused side of the 50 amp fuse not the power in side. If I remember right it is easy to get a short between the two fuses. Something moves or one of the wires touches both fuses. So look closely at your fuse block. The to investigate the OD i would firstly look at the wires to the dash switch including the dash switch. The dash switch may have internally shorted to ground. Take the wires off the dash switch and check the switch with an ohm meter or continuity tester to see if it is shorted. Then test for a break or short on each of the wires. Take the other end of those wires off the OD Relay at terminals C1 and W2 before testing these wires. Then another test would be while these dash switch wires are off, use a jumper across therminals C1 and W2 to see if the OD energizes properly that way. If so, then the circuit wires to the dash switch are what causing the problem. But I also think you have something wrong at your fuse box, look it over carefully.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  13. #12
    Join Date
    Mar 2018
    Location
    Auckland NZ
    Posts
    25
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: Fuses Blowing
    Thanks Luke, I feel the problem is in the fuse block. I will start with there.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
