Fuses Blowing
Walker sim
Hi All,
When I try to engage OD on my Healey 100 BN1 (with a BN2 gearbox), both the 50A AND the 35A below it, blow. Any ideas Why?
Cheers,
Wally Simpson
BJ8Healeys
Re: fuses
Hi All,
Cheers,
Wally Simpson
Wally, it sounds like something is wired incorrectly. Normally, the overdrive is not fused but the pull-in coil in the overdrive solenoid draws a lot of current (about 24A) for a short period of time (until the holding coil is energized, then the current drops to about 1A.) I'm assuming the BN1 or BN2 overdrive wiring is the same as a BJ8. Perhaps the attachment will help you troubleshoot it.
Good luck!
Keoke
Re: fuses
Hi All,
Cheers,
Wally Simpson
When did this problem surface ??
W
Walker sim
Re: fuses
Hi Keoke
About two months ago, previously OD worked fine. I replaced both fuses, engaged OD & again, both fuses blew.
Cheers,
Wal
Bob_Spidell
Re: fuses
Hi Keoke
Cheers,
Wal
Did you use the proper fuses: 'slow-blow,' with the proper rating (the English rating is different than the ones you can typically get at the local parts house)?
W
Walker sim
Re: fuses
Yes, What I can't understand, if there is a problem within the OD, why do both fuses blow at the same time. I obtained the 50A from "Element14" in Aussie. Voltage rating VAC250V (made in China on the packaging). I wonder if there is a fault in the fuse block.
Cheers,
Wally
John Turney
According to the Bill Young BN1 wiring diagram in the January 2019 Healey Marque, power for the OD comes from the fused side (terminal A4) of the 35-amp fuse (This is different than later Healeys). The 50-amp fuse should only go to the horns. The supply side wire to the fuses should be brown (terminals A1 & A3); the fused wire to the horns should be brown with a green stripe (terminal A2). The fused side wires from the 35-amp fuse should all be green (terminal A4).
You could have a connection between terminals A4 and A2, causing power to the OD to go through both fuses. Check the fuse block for this. With a short in the OD circuit, the current is enough to blow both fuses, probably the 35-amp one first, then the 50-amp one.
The next problem could be the OD solenoid or a wire in the OD circuit shorted to ground (earth). Anyone know the inrush current of the OD solenoid?
Healey Nut
Divide and conquer ..... disconnect the wire to the solenoid . Install new fuses and with the OD solenoid wire taped off to prevent short . Turn on OD switch .... do the fuses blow , no connect solenoid with switch on , fuses , blow , yes , bad solenoid .
Fuses blow with solenoid disconnected and wire taped off , short in wiring or fuse block . This is not complicated .
W
Walker sim
Thanks John, I'll check the fuse block, strangely, with both fuses blown the horns still work but the wipers don't.
The car was restored 30 odd years ago then placed in a collection with little use until I bought it. Maybe the correct color wires weren't used which could make it difficult, I'll check.
Cheers,
Wally
vette
I think maybe some wires at the fuse block got switched around. The horn should be on the fused side of the 50 amp fuse not the power in side. If I remember right it is easy to get a short between the two fuses. Something moves or one of the wires touches both fuses. So look closely at your fuse block. The to investigate the OD i would firstly look at the wires to the dash switch including the dash switch. The dash switch may have internally shorted to ground. Take the wires off the dash switch and check the switch with an ohm meter or continuity tester to see if it is shorted. Then test for a break or short on each of the wires. Take the other end of those wires off the OD Relay at terminals C1 and W2 before testing these wires. Then another test would be while these dash switch wires are off, use a jumper across therminals C1 and W2 to see if the OD energizes properly that way. If so, then the circuit wires to the dash switch are what causing the problem. But I also think you have something wrong at your fuse box, look it over carefully.
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
Jim_Gruber Blowing 15A Fuses as soon as I apply the brakes Spridgets 6
S TR6 TR6 blowing fuses Triumph 4
Dudly Spitfire Blowing fuses in my 79 spit Triumph 10
Brosky Heater blower blowing fuses Triumph 6
R Bugeye fuses Spridgets 14
K TR2/3/3A Fuses Triumph 3
K TR2/3/3A 30 AMP Fuses Triumph 2
longbridgehealey In line fuses Austin Healey 25
M Fuses Austin Healey 7
M Additional Fuses Austin Healey 3
F TR2/3/3A Fuses Triumph 10
K TR2/3/3A TR3 Fuses Again Triumph 1
T TR6 Blown Fuses Triumph 1
B Fuses for 1960 BT-7 Austin Healey 3
RickB All 4 parking lights dead, fuses all good? Spridgets 6
W Glass fuses Jaguar 3
I TR6 TR6 correct fuses? Triumph 8
H Tr 3 fuses Triumph 10
C AH 100-6 Fuses/wiring...what did I do? Austin Healey 6
af3683 35A Fuses Triumph 14
M Still con-fused about fuses Triumph 22
A Midget Fuses Spridgets 7
A TR2/3/3A TR3A FUSES Triumph 4
longbridgehealey Bugeye fuses Spridgets 5
Thor lights on without any fuses- Any suggestions Spridgets 6
J Additional fuses Austin Healey 1
Paulus MGB 69 MGB fuses MG 8
D Fuses? Triumph 9
Tinkerman TR2/3/3A TR3A fuses Triumph 9
Tronch Adding Fuses Austin Healey 4
19_again Fuses in'66 B MG 12
B fuses Brit vs US Triumph 5
G Question on fuses Spridgets 9
T "British" Fuses Triumph 4
Michael Oritt Switches and fuses Racing 13
Tinkerman British fuses vs American fuses Triumph 17
G British Fuses vs American Fuses...big difference Triumph 17
C Of turn singals & fuses Spridgets 10
G No More Blown Heater Fuses!!!! Triumph 3
G Burning Fuses & my patience..running out of both Triumph 25
B Using inline fuses? Austin Healey 65
R Fuel pump fuses Jaguar 0
S In-Line Fuses Austin Healey 19
jaybird Stinking, no good, ratzenfratzen fuses! MG 17
tahoe healey Inline Fuses [ and Fuse Theory & Application ] Austin Healey 19
S Wedge TR7 Fuses Triumph 5
Sopwith_Camel MGB-GT blowing fuzes MG 14
ckeithjordan TR2/3/3A Blowing a Fuse Triumph 30
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
