TR6 5 speed conversion
Gliderman8
I think it is. It is one of the best improvements I’ve done to my 6.
I purchased the HVDA kit and sourced a w58 transmission.
It makes driving on the highway easier.
DavidApp
Just about to install an OD transmission in my TR3A. I found an old TR3 transmission with OD and had it overhauled.
I am hoping it will make highway driving more enjoyable.
David
Herk
Look at it another way, if you don't mind the car on the highway as-is, an overdrive or 5th gear means you can regear the rear axle to 4.1 in place of the 3.7 factory gears. Same top speed, much improved everything else.
charleyf
I have converted one TR3 and 2TR4s to the HVDA Toyota 5 speed trannys. Most of my driving is open road with a fair mix of freeway. It is so great to reduce the rpm's even in town or on the freeway. I will add that I also converted the rear axle to 3.45 gears. That conversion is good but not worth the cost.
I have gotten so used to the lower RPM's, even in town I use 5th gear most anytime I am over 45 MPH..
glemon
I love my overdrive transmission, use it on the highway of course, but also in town if driving over 45 or so for any appreciable distance. If my ultimate goal was performance and reliability I would certainly put in a modern 5 speed, as they weigh less than an O/D unit and are probably a little more robustly built and reliable. But if my ultimate goal were performance and reliability I could sell my TR250, buy a Miata or whatever, and have change leftover.
Having the extra gear reduction is nice whether you get it through a 5 speed or an overdrive, the extra tall gearing is not needed in a TR as much as it is in a Spitfire or Midget, but still a welcome addition. Preference for the overdrive unit or a modern five speed is just that, preference. I always wanted a car with electric overdrive when I was young, still get a kick out of flicking the switch and feeling the revs drop.
DNK
Biggest reason
That oil spot in the garage will be gone
tinman58
One of the oil spots will be gone.
I like the HVDA conversion also.
Jerry
Less heat production from the Toyota conversion also. The original gearshift is always hot, not so on the Toyota conversion. In the summer, it makes a big difference. I would like a 5th speed for my old mini, but then again, not enough power to go up a hill at lower rpm.
malbaby
There is a company here in Australia called "Dellow" that makes/made bellhousings to suit toyota. There was a NOS advertised by a private seller last week.
Got_All_4
Put a A type in my 60TR3A and totally trans formed the drivability of the car. If you do any highway or over 45 mph driving you'll appreciate an overdrive of any kind. My preference for the A Type is driving through the hills and shifting all the time throwing that electric switch was much more pleasing and fun then all that shifting. Makes you fell like you got one over something. Originality comes into play too with some. But if your car was not a factory overdrive you can hide the fact that you have a Toyota tranny buy using a Triumph logo shift knob. I now have an Atype and a Jtype ready to go into my TR250 and TR6.
DavidApp
So you use the OD as a 5 gear on the highway.
Just got mine installed and did the first test drive. I will do a couple more drives then put the interior back in the car. So far everything is good.
David
Andy Blackley
I don't mind shifting. My daily drivers for the last twenty+ years have all had 5 or 6 speed gearboxes. Thirty years ago I had a Series II Land Rover with a manual overdrive - talk about shifting! It could work on all fours speeds. When I drive the TR I find myself frequently reaching for the non-existent fifth gear, so I will be installing the HVDA kit this spring. If my commission plate end with an "O" it might be a different story. BTW it uses the stock TR shift lever so need to buy a new knob. I did however buy a nice new black knob with the correct 5 speed pattern. Until you look very closely it appears stock.
One thing I'll say for the W58 - I don't see many forum posts bitching about how its not working.
Gliderman8
My W58 has been nothing but a pleasure to drive. When I bought the car I checked the commission number and saw that it included the factory overdrive. After I got it home I discovered that at some point in its life the original overdrive was removed!
It's all good now.
OldGuy51
Dont you find that Finding a Toyota W-58 is almost impossible , Asking price is absurd ! Then if its outta the car try to prove it is a W-58 to begin with. Not that people lie , but if they dont kow for sure that should be what comes outta their mouth. Youd think "Asian" would have the secret. What has to be change to use a MX5 5 speed ?
bammons
Jim Cox has W58's in KY. 502-376-9149. With guarantee. I have the HVDA installed but have not driven yet. With the wife in the car on the road I believe it will be better (for her). Bruce
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
roscoe 5 speed conversion question Austin Healey 9
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
rjc157 TR6 5-speed conversion Triumph 7
E TR6 Eaglegate 5-speed conversion help Triumph 1
mctriumph For Sale 5 speed conversion kits [formerly by eaglegate] Triumph Classifieds 3
rjc157 TR6 5 speed conversion Triumph 7
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
M The value in 5 speed conversion Spridgets 18
Rut 5 speed conversion Spridgets 4
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
Keith_M 5-speed conversion or not Spridgets 57
Mickey Richaud Midget 5-Speed Conversion Spridgets 6
bugedd 5 speed conversion trans oil Spridgets 7
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
JodyFKerr Spitfire Spitfire 5-speed conversion Triumph 9
Rut 5 speed conversion wish list Spridgets 28
B Healey 5-Speed Conversion Austin Healey 27
Gliderman8 5-Speed Conversion - Shifter Triumph 10
Gliderman8 5-Speed conversion Latest Triumph 13
HealeyPassion Question for 5 speed conversion guys Austin Healey 13
jhorton3 New Project...5 Speed Conversion! Spridgets 17
M AH 100 5 Speed conversion questions Austin Healey 21
prb51 Gear ratio/speed conversion Triumph 0
healeyboz 5 speed conversion Spridgets 15
CCURTISS T-Series TF Engine Lift Points for 5 speed conversion MG 3
CCURTISS T-Series MGTF 5 Speed Conversion MG 3
64rocksprite 5 speed conversion thoughts? Spridgets 7
gsalt57tr3 5 speed conversion for the 1500cc midget Spridgets 5
J Morgan 5 speed conversion Other British Cars 8
Sparkie New 5 speed conversion for 280i guys TVR 32
mgbmedic MGB MGB or TR6 -- 280Z 5 Speed Conversion MG 2
Bob McElwee Toyota 5 Speed Conversion Questions Austin Healey 10
budk1953 5 Speed Conversion Question MG 6
Hap Waldrop Rivergate 5 speed conversion questions Spridgets 42
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
kyreb1862 MG 5 Speed Conversion MG 20
S 5 speed 210 conversion and shifter question? Spridgets 7
PeterK 5-speed conversion pic Triumph 17
W 5 Speed conversion gear box MG 3
S Rivergate Five Speed Conversion Spridgets 6
77_MG_Midget 5 speed tranny conversion Spridgets 9
B Rudd Speed Conversion Austin Healey 3
MGA Steve Spitfire Spitfire 1500 5-speed tranny conversion Triumph 0
