Results 1 to 18 of 18
Thread: Carpet and upholstery installation
  1. #1
    Join Date
    Jul 2019
    Location
    Omaha, Nebraska
    Posts
    8
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I am restoring a 59 TR3, which came with NO interior. I have purchased new carpet and interior kits, which came with no instructions and would appreciate directions. I have done other cars, but TR3's are definitely unique. Are there resources or videos available? Suggestions appreciated.
    Gene
  2. #2
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    183
    Thanks Thanks Given
    8
    Thanked in
    Re: Carpet and upholstery installation
    SANY0005.jpgI just did mine. Carpets are easy, just lots of contact cement. I also put "Killmat" under the carpet for sound and heat. Definitely recommend over the hump to keep your right leg cool. Vinyl is another story. Difficult locations are the wheel well covers and the curved piece right behind the door. Put a pad under the wheel well cover so it will stretch flat. The curved piece (name?) required a lot of heat and patience. I never did get mine perfect. You should be able to locate lots of previous posts on this subject.
  3. #3
    Jedi Warrior PatGalvin's Avatar
    Join Date
    Jan 2010
    Location
    Folsom, CA
    Posts
    797
    Thanks Thanks Given
    Thanked in
    I am super happy with the Dynamat that I installed across the entire floor and firewall of the car. The sound deadening was definitely worth the effort. And reduction of exhaust heat. Thin stuff, lined with a heavy aluminum foil. Easy to install.
    Pat
    59 TR3A TS38096 L
    1968 TR250 CD6021LO
  4. #4
    Freshman Member Leatherman's Avatar
    Join Date
    May 2019
    Location
    Carlisle PA
    Posts
    16
    Thanks Thanks Given
    Thanked in
    Gene, I ran across a u tube video last summer that covered the process of installing the upholstery kit. Sorry I cant give you a link but if you go to u tube and do some searching on installing upholstery on a TR3 I’m sure you will find it. I will be doing mine in a couple of months too and I will be looking it up as well. Who’s kit did you get?
  5. #5
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,393
    Thanks Thanks Given
    6
    39
    Thanked in
    There are are a few differences, but try this thread:
    https://www.britishcarforum.com/bcf/...23-Upholstery-!
    John
    1955 TR2
  6. #6
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    195
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    +1 on John’s excellent tutorial. Like him, I went with John Skinner. Prices were actually cheaper for what you get from the big three over here, at least last year. I also sprung for the thin padding for the wheel well from Macy’s garage.
    There’s also a few clips on YouTube . I’d like to show you mine, but I’m still reassembling the mechanicals!
  7. #7
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,823
    Thanks Thanks Given
    13
    45
    Thanked in
    another +1 on John's thread. I refereed to it over and over as I went through my interior rebuild. He has step by step photos and directions for almost all the interior.
    I also used the kit from John Skinner but could not get along with his seat padding (Foam material) so I got the Roadster factory padding kit which I found much easier to work with. There was some thin fabric backed foam in the Skinner kit that was intended for the seat cushion. I used that to pad the rear wheel wells.
    David
    TR3A TS75524L
  8. #8
    Join Date
    Sep 2009
    Location
    Northern VA, USA
    Posts
    195
    Thanks Thanks Given
    7
    1
    Thanked in
    1 Post
    Oh, yes I forgot that... I also substituted the TRF horsehair for the Skinner foam!
  9. #9
    Join Date
    Jul 2019
    Location
    Omaha, Nebraska
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Steve--thanks for the response.
    Gene
  10. #10
    Join Date
    Jul 2019
    Location
    Omaha, Nebraska
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Thanks--I'll try to find it. I got the Moss kit with leather.
  11. #11
    Join Date
    Jul 2019
    Location
    Omaha, Nebraska
    Posts
    8
    Thanks Thanks Given
    Thanked in
    John--thanks. This helps with some of what I need--still looking for from the doors on back.
    Gene
  12. #12
    Join Date
    Jul 2019
    Location
    Omaha, Nebraska
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Thanks, David!
  13. #13
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,596
    Thanks Thanks Given
    8
    Thanked in
    The doglegs behind the doors can be a bear to get looking good. Geo Hahn made a jig to hold the dogleg from a 3/4" board. It works great and makes it much easier to get them wrinkle free. I did mine in leather and and some heat and water got everything to stretch jut fine. The red one is mine.
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  14. #14
    Join Date
    May 2019
    Location
    Carlisle PA
    Posts
    16
    Thanks Thanks Given
    Thanked in
    I went with Roadster Factory for my bright red leather kit. The leather has a pretty heavy print to it compared to the matching vinyl. It is also a brighter red than what I was expecting. More orangey than what was in my car. I’m on the fence as whether I like the color or not. I don’t like the difference in grain between the leather and vinyl. Anyone can tell me if the 60’s cars had a heavy grain to the leather back then?
  15. #15
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    183
    Thanks Thanks Given
    8
    Thanked in
    Martx-5. That is awesome. ****, now I have to do mine over again.
  16. #16
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,035
    Thanks Thanks Given
    1
    8
    Thanked in
    Art,
    When covering the dog leg piece did you work the leather until it formed over the metal and only then apply glue? Was the material then cool and dry before the glue went on?
    Charley
    1962 TR4
    1963 TR4
    1959 TR3A A work in progress.
  17. #17
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,596
    Thanks Thanks Given
    8
    Thanked in
    Quote Originally Posted by charleyf View Post
    Art,
    I applied the glue first. I'm pretty sure it was 3M Super 77 (although it might have been Super 90). Right after applying the glue on both the metal and some on the leather...not where you grab the excess leather to stretch. I used a heat gun and water (in a spray bottle) to stretch the leather onto the metal. After it dried, I trimmed the excess, folded the leather over the back and glued it down. I used some Welwood contact cement that came in a small jar with an applicator brush inside for that.
    Art
    '58 TR3A TS236xxL
    '07 Mazda RX-8
    '11 Mazda CX-7
  18. #18
    Join Date
    Jul 2019
    Location
    Omaha, Nebraska
    Posts
    8
    Thanks Thanks Given
    Thanked in
    Thanks--great idea to use the jig.
    Gene
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
