Wiper Motor Problem Not Working
mxp01
All:
I’ve had an ongoing problem with getting the wiper motor on my 59 BE. I’ve had issues where the motor ran briefly, smoked, and stood working. I replaced the motor (same issue). We bench tested the motor (it worked). I replaced the wiper motor switch. Today we hooked up everything and the fuse fuse immediately blew.
Thoughts?
MXP
Bayless
I would look for a bind or friction in the cable, tube and wheel boxes. Maybe just dried grease.
Billm
Mike
I will bet that the wire connections are incorrect. Verify them
Billm
M
mxp01
Bill wins the prize: We re-tested the motor (working) and the tension on the cable moving the wipers (free movement). There were two loose black wires under the dash. I swapped one of those into wiper switch (removing the other) and everything turned on and operated fine. Everything.
I can't explain those other two black wire (to where they should go). I taped them up and secured away. There is also a white wire (with a bullet connector at its end) that I can't account for either.
Otherwise, it's working as designed.
MXP
JPSmit
black should <should> be ground
R GT6 Wiper Motor problem and time capsule Triumph 4
G Wiper motor problem. Spridgets 1
MGTF1250Dave Windsheild Wiper Motor Problem Triumph 9
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
J TR2/3/3A Wiper Motor bracket Triumph 5
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
sparkydave Wiper motor '77 Spridgets 2
J TR2/3/3A Wiper motor wiring Triumph 4
D TR5/TR250 Windshield wiper motor Triumph 9
J TR2/3/3A Wiper Motor Gear Triumph 11
S TR2/3/3A Wiper Motor Troubleshooting Triumph 6
R grease for windshield wiper motor- BJ7 Austin Healey 4
steveg Wiper motor install error - warning Austin Healey 9
P WANTED: Bugeye Wiper Motor Spridgets 0
S TR2/3/3A Wiper Motor Parking Question Triumph 8
P Bugeye Windshield Wiper Motor Spridgets 3
Jim_Stevens TR2/3/3A Wiper motor mount Triumph 4
maxwedge5281 TR6 tr6 wiper motor wiring Triumph 15
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Scotsman TR4/4A TR4A wiper motor rebuild Triumph 8
Scotsman TR4/4A TR4A wiper motor questions Triumph 2
K TR2/3/3A Wiper motor testing? Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
rjc157 wiper motor Austin Healey 0
Rob Glasgow Wiper motor rubber mounts Austin Healey 5
J Wiper motor 100 degree sweep gear ??? Restoration & Tools 7
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
rjc157 wiper motor Austin Healey 6
D Wiper motor mounting Spridgets 0
T TR2/3/3A wiper motor parking Triumph 7
