AH 300O MK1 Choke Knob Position
dallo
On the mark 1 AH 3000 Where is the choke bracket affixed, i took a photo at Ah spares who had a mk1 in their show room photo attached and it seems to be affixed to a bracket , but not sure if this is correct or a after mod, i know on the mark 2 it was in the dash board.
Anyone with a mark 1 who could advise,
Mine is now right hand drive the photo is of a left hand assume it would be in the same position?
Phil
Administrator
Boss
Hi Phil. You posted your question in the "FORUM Help" forum. The FORUm Help forum is meant as a place to ask questions about navigating the forum (how to do things like post pictures, quote someone in a reply, etc.). I am moving your post and your question to our "Austin Healey" forum where you are more likely to receive answers to your Healey-specific question. I will leave a pointer in the original forum, but if you're reading this, you are now in the Austin Healey forum.
John Turney
That's the original location of the choke knob on a 100-6. On a 3000 Mark 1, if it has a manual choke, the knob is on the dash above the cold air "Pull" knob.
Lin
Hi Phil,
My 60 BT7 is 4422. I have had it since 1971. The choke was under the dash on my car as in your photo.
Lin
red57
Lin, Yours may have been modified before you got it.
My '60 BT7 is 4646 built date 15-17 September, 1959 and had the thermo-electric choke when I got it in 1987.
I promptly removed the thermo-electric and mounted a manual choke as in Phil's picture.
According to the Clausager book the thermo-electric started with car 2194 and ended with BN7 5234/BT7 5310. When they discontinued the thermo-unit n Nov. 59, they placed the choke in-dash like Steve's picture. It doesn't say for sure but presumably prior to 2194 it was probably under the dash like the 100-6 predecessor.
Todd78d Sprit MK1 gear box filler Spridgets 2
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
K MK1 Cooper S? British Motor Corp 3
M General MG Midget MK1 windshield replacement MG 2
K Disc Brake Conversation to MK1 Midget Spridgets 2
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
LarryK Jaguar MK1 restorations Jaguar 15
B 1959 mk1 3.4l jag Jaguar 4
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
S XJ6 Mk1 clutch slave question Jaguar 0
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
Csarneson Bargain 3000 Mk1 in Colorado Austin Healey 1
A Mk1 rear deck restoration Spridgets 0
A Chassis front 'H-section' Mk1 Spridgets 5
D Charging issue on mk1 British Motor Corp 1
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
R GT6 Mk1 Pulley weighting marks Triumph 6
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
C MK1 3000 fan belt Austin Healey 1
B GT6 Mk1 GT6 glass domed fuel pump Triumph 6
K 61 Mk1 auto to manual OD gearbox swap? Jaguar 0
N Bulb holder Mk1 3000 Austin Healey 5
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
C Mk1 3000 screen/windshield fitting Austin Healey 7
A Mini Mk1 dash heater knob British Motor Corp 0
C Servo fitting MK1 3000 Austin Healey 1
C Mk1 3000 side screens variations Austin Healey 13
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
D MK1 Rubber Tunnel Cover Spridgets 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
RickB MK1 Midge radiator value? Spridgets 2
I 2000 MK1 posted on CL Triumph 2
dklawson GT6 Head Re-Torque - Mk1 GT6 Triumph 8
S MK1 midget measurements Spridgets 0
brgrmyster GT6 New Molded Carpet Set GT6 Mk1 & 2 For Sale Triumph 7
Boink Color Wiring Diagram for Mk1 Spridgets 8
C Trick Midget Mk1 Racecar Spridgets 15
Eddie6775 GT6 Installing Fiero seats in My GT6 MK1 Triumph 24
dklawson GT6 Mk1 GT6 Engine Rebuild Triumph 36
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
K MK1 Seat Repair/Rebuild Triumph 5
C Some cool Pics of my MK1 Spridgets 25
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
M bn-7 [mk1] block casting number Austin Healey 2
