BN4 Locking Door Handle Removal Suggestions
Kainopong
Member
Hoping someone can help - I want to re-key my drivers side door lock to match my ignition and boot and struggling to find a way to get the nut off of the screw in the back portion of the handle. The screw and nut accessible when you open the handle is no problem. Its that second one that is the issue. Do I have to remove the handle to re-key?
If so and anyone has a slick solution please advise!
John Turney
You will have to remove the handle to rekey. There is a pin inside the door that has to be removed to extract the lock cylinder. I didn't bother. I learned when I was stationed in Hawaii to never lock the door on a roadster or convertible.
dougie
Ditto.....
K
Kainopong
Member
I was able to remove the nut with some difficulty and get the handle out! While not looking forward to re-installing that nut will re-key and get the missing gasket on and re-install. Thanks gents! John
dougie
My guess....becuase you can just cut through the canvas soft top with a butter knife.
John Turney
Hey John, why is that?
Because it's too easy to slash the top, and replacement tops had to be shipped from overseas. I know you know how hard it is to get a new top installed on a BJ8. If I had to have anything in the car, I would lock it in the trunk.
red57
I agree, even putting the tonneau on can backfire - I had a nice 8 track stolen from my BN1 in 1972 and the guy couldn't be bothered with snaps and a zipper..... apparently a knife was faster. Was really a shame too because I had just had a buddy rewire the tape deck internally to convert it to positive ground and I'm sure he would have wired it negative and fried it the first time he tried to use it.
Dave
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
A 100/6 BN4 Restoration Austin Healey 4
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson Early BN4 steering box pitting Austin Healey 16
Csarneson BN4 Cam Gear Install Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
K Correct side screen nut for early 58 BN4 Austin Healey 14
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Bugeyze BN4 Windscreen Shims? Austin Healey 13
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
L 100/6 BN4 Fuel Tank feed Austin Healey 5
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
L Need a early BN4 hood bow Austin Healey 1
