LED bulb/resistor wiring question
Michael Oritt
I purchased two of the Moss 170-941 red LED bulbs to use as tail-lights/brake-lights to replace the standard 1157 dual filament bulbs on my 100 (I have the reflector pods electrified and wired for turn signals). In addition to the bulbs I also purchased, at Moss's suggestion, two 170-965 Load Resistors.
The instructions for installation of the resistors simply talk about the resistor's being installed between the power and ground leads to each fixture but it does not specify which power lead. My question is: do I connect the ground lead to the tail light power lead or the turn signal power lead or does it matter? I cannot envision connecting it to both as that would defeat their separate function.
TIA....
Michael Oritt
Michael Oritt
Steve--
Thanks. I also posted my question to the autox.healey email list and got a number of responses saying just t
that.
Michael Oritt
Michael Oritt
When I ordered the bulbs from Moss I asked the associate if they would work in a 100 as its tail light lenses are much flatter than those for later cars and he assured me that they would. In fact LED bulb is about 5/16" taller than the incandescent bulb and it will not fit under the present lens. My choices are to either find a shorter LED or go to the later rounded glass lens as used in BN/BT cars. I am hoping to go with the first option.
BTW since I have previously transferred my turn signal function to separate electrified reflector pods I now realize that I do not at this time need to install the ballasts since there will be no flasher function for the bulb--merely side and brake function only. But since I will probably next replace the front bulbs and those in the electrified pods with LED's the ballasts will not go to waste.
Thanks all for your patience....
If you have an incandescent bulb in the front turn light, wouldn't that give enough resistance in the circuit without adding a resistor?
The recommended, added resistor is required to REDUCE the total resistance in the circuit, by providing an additional, 'parallel' path to ground (IIRC, the total resistance in a parallel circuit is the sum of the inverses of all the resistances; a resistor in series would increase total resistance by its value). LEDs, like most solid state components, have high impedance, meaning they draw relatively little current (compared, for instance, to an incandescent bulb, which produces light by heating a wire; LEDs emit light--hence the name--by using current to excite the the electrons in their atoms to higher energy levels). Since LEDs draw much less current when energized there isn't enough current draw to activate a typical, bi-metal strip-type flasher relay (one side of the bi-metal strip heats up and cools more than the other, causing the strip to move back and forth and open and close a points set, causing the flashing; old school household thermostats operate on the same principle). The additional resistor causes the circuit, when switched on, to draw enough current to activate the flasher.
Edit: I just recalled that the flashers, I think, use a spring-loaded wire that stretches and contracts, not a bi-metal strip. But the result is the same, when a turn signal circuit is activated current flows through the wire, causing it to heat and stretch so the spring can pull the points apart, then it cools, contracts and closes the points again, starting the cycle over).
Edit 2: I believe this is why, in a traditional turn-signal circuit, when one the bulbs has failed open, you have less current draw so the wire doesn't get as hot and blinking is quicker. With LEDs all round, you essential have almost nil current draw, not enough to activate the flasher so the LEDs will light up--voltage is still applied--but there isn't enough current draw to heat the wire in the flasher.
Jack T
I replaced both rear lights on my BT7 with LEDs. One side blinked normally with no resistor, the other side would not blink. I added a resistor at the terminal of the flasher relay for the appropriate bulb and it works perfectly. There was no need to put it in line, just adding the load did the trick.
AUSMHLY
How noticeable is the brightness difference when swapping the filament bulbs to led with directionals... with headlights your going from 2700 Calvin to 5000-6500.
Bulbs in headlights are projected through a clear glass lens, where as the directional lens are not clear, they're either amber, frosted clear or red I believe.
So I guess with directionals we're looking at (pun) increase in nits? From what X to what X?
Don't have numbers for you, but LEDs are considerably brighter. I got tired of people telling me my brake lights weren't working--in part, I suspect, because I coast in gear to red stoplights--so I put red LEDs in the stoplight circuits in my BJ8 (on driver side, for comparison). Note the lights are red; the distortion is due to saturation:
Edit: And these are just the running lights; the brakes are brighter.
AUSMHLY
Bob, nice to see the reflectors are above the bumper, as intended.
Has anyone compared the difference between installing a clear led bulb vs a red led bulb in the red housing?
I don't understand the physics, but you're supposed to use the same color bulb as the lens, according to at least one 'authority' (the Litezupp people I bought the LEDs from). Black absorbs all the colors of the spectrum and white reflects all of them, so a red lens would pass more red than other colors, hence more brightness (that's my guess, anyway).
Edit: If there wasn't a difference, no one would bother with the other colors I suspect. Early on, only red LEDs were available, then they figured out to make different colors (yellow, blue, green). I suspect it's due to trace elements in the NP junction that comprises a diode.
John Turney
One LED supplier said that if you use a clear bulb behind a red lens, you get "pink". Not the color you want. The rear red lenses absorb anything but red.
steveg
The site is, however, ambivalent--'ambervivalent?'--about amber lenses: white bulb for greater brightness, or amber for truer color?
Amber it is (turn signals don't usually need to be seen from 500yds). I left the incandescents in my turn indicators (didn't want to mess with resistors or a SS flasher).
bob hughes
Just a point for the earlier cars, I have seen an LED bulb that flashes red on stop and yellow on turn all through a red lens. Bi coloured bulbs are not new, but there must be a mighty powerful yellow light to get through the red lens. I have not found the source of supply yet but I know that they are expensive. I have been in discussion with Classic Car LEDs over here, and they say that they are looking into it but that is as far as it has gone.
:cheers:
BBH
Bob, See my link above. Better car lighting is selling these and I believe that they are the same ones as being sold by Bill Rawles as part of his conversion kit
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Stinky 1157 LED Light Bulb Dissapointment Triumph 8
PAUL161 T-Series MGT 7 inch LED Headlights MG 1
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 14
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
Scotsman TR2/3/3A LED headlights Triumph 4
