I screwed up - Bosch VE pump.
70herald
Well to try and stop a big fuel leak on my Nissan Serena. (LD23 diesel Engine) I eased off the back of the pump to replace the o-ring between the aluminium body and the cast iron head (part where the high pressure pumps are and the outlets to the injectors. THAT part went OK I think (nothing escaped and it all went together easily)
but now I have 2 problems:
1 the pump won't prime.
2 Trying to get to the head I took off the accelerator and top plate but now the "idle mixture" potentiometer may not be set properly - WHAT is an Idle mixture control on diesel engine? diesel has the air fully opened and all control is from the amount of fuel injected. Any ideas?
70herald
OK I finally got it to prime and realized that I put the accelerator arm on a bit rotated so it wasn't opening the throttle at all. Now it starts. warm and cold idle are high but that is just two screws, probably full power will be a bit low. That will be a pain since it has a tamper nut.
Still trying to figure out what the potentiometer does.. (doesn't seem to do much actually)
Intrisk BJ8 Front suspension screwed bush housing / threaded bush housing re-assembly gap Austin Healey 1
A almost screwed up Triumph 8
dklawson Oil Leak - I Screwed Something Up. Triumph 8
68_sprite CSI screwed up their facts Austin Healey 5
livinginthepast self-delete | sorry, i screwed up. Spridgets 1
T I'm Screwed, part II..... Triumph 4
T I'm Screwed! Triumph 37
jlaird Think something is screwed up Spridgets 20
regularman Important question [I might have just screwed up] Spridgets 8
LuckyLuke Big Healey heat shields screwed or also glued? Austin Healey 5
jlaird I screwed up, maybe Spridgets 13
DrEntropy Think I just Up-screwed... MG 2
G I screwed up another part..... Triumph 9
G Got screwed by a local machine shop Triumph 14
A Polyurthane Bushing - Screwed Up? Spridgets 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
7 No more Bosch tools for me Restoration & Tools 4
JPSmit Bosch Coil question Spridgets 14
A TR2/3/3A Bosch ruled the day Triumph 2
aeronca65t Spitfire Bosch distributor in Spitfire? Triumph 3
Z Bosch Fuel Distribution Unit TVR 5
Z Bosch Fuel Distribution Unit TVR 2
hondo402000 Bosch alternator conversion Triumph 3
DrEntropy Bosch Plat Plus NLA? Other Cars 6
SCguy Bosch Fog Light Cover! Triumph 1
SCguy Wedge TR8 Bosch Fog light covers Triumph 8
T On a positive note - new Bosch alternator rocks! Triumph 21
T Paul - did you change any wiring for the Bosch? Triumph 3
tomshobby Bosch alternator Triumph 30
Brosky TR6 Fiesta Bosch Bolt on TR6 Alternator Triumph 35
bmurphy7369 Bosch Blue Coils... for older OPUS systems? Jaguar 3
Woodie bosch spark plug wires Spridgets 5
rodesmg bosch sparkplug Spridgets 1
Got_All_4 HELP ON BOSCH 55 AMP ALTERNATOR CONVERSION Triumph 1
aeronca65t Bosch Graphics Other Cars 4
LastDeadLast Bosch Alternator Wiring Question Triumph 1
K Bosch Fuel Pump Problem Triumph 4
O 110-amp Bosch Alternator Upgrade MG 47
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
M 1500 Midget water pump weep hole Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
