Modern Cars [and some perspective]
glemon
Used to intimidate me a bit. Just did a valve adjustment on my wife's 2007 Honda Fit. YouTube has instructional videos for everything, and that certainly helps a lot.
Anyway, the fit is about the same age (and twice as many miles) as my first car when I bought it, a 1967 Sprite.
Don't get me wrong, I love old sports cars, then and now, but the Honda has needed, other than consumables, brakes, tires, fluids, a few bulbs, only one suspension bushing and one idler pulley in the 13 years we have owned it. No rust on the body, no rusted on bolts. The Sprite had some of both.
So I guess there is such a thing as progress. That being said, I could access the valves on the Sprite in about 5 minutes, the Honda took nearly an hour to get in. Had to remove the intake manifold, intake plenum, battery, and various other hoses and electronics.
The rockers themselves have the same kind of slotted bolt and locknut adjustment as an old LBC. Pretty easy once you got in. Despite the complexity, things are well engineered, while access is an issue for some things, fit is precise and it only goes on one way and that is the right way. A contrast to getting the gland nut seal right on an old SU carb, which is a bit more of a trial and error art.
Sort of a long, rambling post, to sum up, not really harder or easier, but the challenges are different.
JPSmit
Ah ... but which is the more fun to drive?
:driving:
On an interstate in summer or the dead of winter?
Or a winding road in spring?
Different horses for different courses.
Well done on the FIT - anything under the hood of any of our dailies still intimidates me (except the washer fluid)
Bayless
My grand daughter had a Honda Fit until a lady T-boned it. She loved that car.
glemon
glemon
Oh, the old ones are more fun to drive, and more fun to work on too. Also much more reliable than urban myth would rate them at, but they do require a little more attention to be happy.
waltesefalcon
I agree with the above, I have often driven forty+ year old cars as dailies without any issue. They do need more upkeep but the ease of working on one easily offsets the hassle of doing anything on a new car.
Deleted member 8987
Just think...when you get rid of that Honda, you can tell folks "I had a fit..."
Seriously...who think of these names, anyway?
JPSmit
I don't know I for one am very glad I finally got a Soul! :grin:
AngliaGT
You could be out of your Element.
DrEntropy Some crabbing about 'modern' cars Other Cars 11
F Old Cars, Modern Radios Triumph 15
R6MGS *modern* cars.....rant Other Cars 21
G Modern cars are spoiling me Triumph 10
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
M TR5/TR250 Compatible Modern Tire Size Triumph 5
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
M Fitting a modern radio Austin Healey 9
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
billspohn Modern Classics-to-be? Other Cars 33
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
M Modern Parts & Service Spridgets 21
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
Healey Nut Modern accoutrements Austin Healey 23
rjc157 Modern Radio Austin Healey 12
glemon Modern Morgan? Other Cars 3
C BMW or other Modern engine-What would you use? Austin Healey 33
Sarastro T-Series Modern Electrics for a TD MG 9
M_Pied_Lourd TR2/3/3A Modern Paint Reference Numbers Spa White Triumph 7
5 Modern [Burlen] SU fuel pumps Austin Healey 7
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
rjc157 modern radio Austin Healey 5
Bradhowesable TR2/3/3A Modern audio in a Tr3A? Triumph 13
aeronca65t "Modern" classic British Motorbikes 4
K Modern Epoxy instead of Welding? Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
K TR2/3/3A Modern Fuse Box on a Tr3? Triumph 7
drooartz Removing modern radio MG 5
cbrvfr Running modern accessories with positive ground? Austin Healey 4
newmexTR3 TR2/3/3A TR3 & Modern Art converge Triumph 5
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
dougie "Modern" Healey Commercial Austin Healey 3
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
bighealeysource Modern color code for MG red MG 3
jhorton3 Modern Radios Spridgets 10
prb51 Modern Starters on Tr's Triumph 10
S Modern day Spridget? Spridgets 8
MTribe modern paint code for Signal Red? Triumph 5
A Old English white modern equivilent? Austin Healey 12
John_Mc Modern marvels Triumph 2
7 How often do you change... [on a modern car] Restoration & Tools 8
MadRiver Modern or rebuilt alternator? Triumph 14
Thor Modern temporary spare tire that might fit 1500? Spridgets 0
