• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
Lights don't break
Gliderman8
Just noticed the lights at the top of the screen. I'm using a MacBook and as I run the cursor along the lights they do not break. I do however get a small color dot below the light in the same color as the light. No big deal, but I just wanted to let you know.
Administrator
Boss
Yep, I suspect it has to do with the fact that I have moved the site from http:// to secure https:// . Seems the plugin (which was developed years ago and is no longer supported) references some code that uses the http:// protocol for the animation of the lights breaking. When I have some time I will attempt to resolve the issue, but it's probably not going to be a trivial fix.
Deleted member 8987
Just so you have a broader understanding of the scope....XP, with Firefox and Mypal both
Administrator
Boss
I think the issue is independent of browser. I think it has more to do with the fact that the site is now using SSL and that plugin for the lights wasn't made to be used on an SSL encrypted site.
LarryK
It's liveable, noticed it this morning. Figured something new was in progress.
GregW
Platinum
I got them to break as normal. You have to unblock the Flash script in your browser. In Chrome, the blocked script shows up on the right side of the address bar. I also had to turn Flash back on in settings.
JPSmit
Glad you aren't taking it lightly. :grin:
John Turney
Got them to break, but no sound.
JPSmit
Most operating systems no longer support Flash - seems like html5 is one of the new standards.
JPSmit
Besides it's Christmas - we have to help to make the season bright!
JPSmit
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
D TR6 Rear lights don't work. Grounding Problem ? Triumph 14
V Gauge lights don't work [First post, help] Triumph 16
zoohow TR2/3/3A lights in series Triumph 2
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
Jcape Lights Spridgets 2
A 100-6 Brake Lights Austin Healey 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
O Spitfire Tail lights not working Triumph 6
D Brake Lights Austin Healey 7
edkap2002 TR6 Brighter instrument lights? Triumph 0
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
drooartz MGB Early tail lights on later car MG 17
LAW75 Instrument Panel Lights Austin Healey 9
JFS Wedge Brake and Tail lights Triumph 3
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
jfarris TR2/3/3A Dash Lights Triumph 3
J LED lights for PL 700 Restoration & Tools 12
bighealeysource LED Instrument Lights Austin Healey 12
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R Grounding Side Lights Austin Healey 4
R bugeye tail lights Spridgets 6
R bugeye side lights. Spridgets 0
Healey Nut Rally Lights Austin Healey 22
E Gauge Lights Austin Healey 4
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
P LED Brake Lights Austin Healey 2
T Spitfire Spitfire lights Triumph 7
N TR5/TR250 amp gage shows discharge when lights are on Triumph 39
O Brake Lights Inoperative Austin Healey 11
S TR6 tr6 courtesy foot well lights Triumph 10
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
K TR2/3/3A Dash Lights Triumph 3
K TR2/3/3A Blinking the Brake lights? Triumph 5
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
C How to install Stone Guards on driving lights? Austin Healey 7
C Wiring for two front Driving Lights? Austin Healey 22
I General TR TR6 won’t start, no lights Triumph 12
R Brake Lights Austin Healey 23
R No brake lights! Spridgets 2
Michael Oritt Lucas 576 lights Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A re- solder my dash lights Triumph 6
R TR2/3/3A Positive-ground LED lights Triumph 13
FlyingCat Spitfire Courtesy Lights Triumph 2
I TR6 Fog lights part 2 Triumph 1
Wana Brake lights on all the time Austin Healey 41
