Page 4 of 4 FirstFirst 1234
Results 61 to 64 of 64
Thread: Fuel Shutoff Valve
  1. #61
    Jedi Hopeful ckeithjordan's Avatar
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    167
    Thanks Thanks Given
    Thanks Thanks Received
    8
    Thanked in
    Re: Fuel Shutoff Valve
    John and Others,
    I still haven't fitted your machined part to the shutoff valve on my car, which is original (it's at the body shop for metal work and a repaint). I did try, however, to fit your part on a valve from Moss. Here's what I found:
    Moss part
    Shaft measures .447 inch
    Cork measures .449 inch
    Chamber measures .493 (I guess this allows for swelling of the cork piece?)
    Your machined part
    Piston .508 inch
    Over O rings .532
    As you can see, your part as machined won't fit the chamber of a Moss part. Just FYI.
    Keith
    1957 TR3 TS20447LO (2017-)
    1962 TR3B TCF1183L (1979-1982)
    1966 Spitfire MKII (1972-1975)
  2. #62
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,427
    Thanks Thanks Given
    6
    41
    Thanked in
    Quote Originally Posted by ckeithjordan View Post
    More the .044" is allowance for ample leakage LOL. Whereas the cork swells when new, after a year it begins to shrink again. Your knowing you have a repro valve may explain the difference in cylinder sizes. I have been told by 2 they fit as I sent, 2 that they needed only some minor opening with a file, and 2, like you, where they aren't even close. I am thinking the repros are the difference.
    John
    1955 TR2
  3. #63
    Join Date
    May 2017
    Location
    Shawnee, KS
    Posts
    167
    Thanks Thanks Given
    8
    Thanked in
    Let me revise some of the numbers on the Moss repro version:
    Cylinder (plunger) .448
    Cork .492-.493
    Inside chamber .491
    Much closer tolerances than I described earlier, but still smaller than machined piece. As I mentioned earlier, I have not measured, nor tried to install in my original-with-car valve, as it is at the body shop. Once I get the car back, I'll take it apart and see.
    I think you're probably right, the repros are different measurements compare to the originals.
    Keith
  4. #64
    Join Date
    Aug 2019
    Location
    Cherokee Village AR
    Posts
    31
    Thanks Thanks Given
    Thanked in
    I must have a repro piece also.
    I think my address is in your message file but PM me if you need it.
    [IMG]file:///C:\Users\Owner\AppData\Local\Temp\msohtmlclip1\01\ clip_image001.jpg[/IMG]
    1962 Triumph TR3B
    TCF2326L
    Jim Martin
    1962 Triumph TR3B
    TCF2326L
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
