TR4/4A Door check straps
Ron Trottier
I'm removing the doors on my '66 TR4A IRS restoration project and the door check straps are riveted at the pivot point joining the two halves. Should I just grind off the bottom section of the rivet to separate the two parts or is there an alternate method of removal without destroying the rivets?
Thanks,
Ron
NutmegCT
Ron - just a thought, but if you're replacing the straps, you could use pop rivets to attach a new strap to the end of the old strap (if it's still good).
Edit: I think removing the rivets is your best choice if you're replacing all the hardware.
Tom M.
R
Ron Trottier
Thanks,
The straps are still good and I would like to keep and reuse the originals if possible. Is there any way to get the door off without grinding off the original rivet bottom at the strap pivot point?
Thanks,
Ron
TRopic6
Ron, I believe the 4A had the same check strap as the 6. I carefully filed the bottom center of the strap pivot rivet and then used pliers to squeeze the bottom of the rivet. I was then able to pull the rivet out and separate the check strap halves. I replaced the rubber buffer at one end and reassembled. You can rejoin the check strap with a small bolt but I wanted an authentic look so put the original rivet back in. Jeff
TRopic6
Here are pictures of the complete check strap and with the original rivet removed. I used some needle-nose vice-grips to squash the flare at the bottom enough to be pulled up & out of the pivot. Its a soft metal. I needed to remove the doors for restoration and paint P1110085.jpgP1110087.jpgP1110086.jpg prep.
R
Ron Trottier
Thanks, that is the method I will use once I get to the door removal stage. I was able to adapt my wooden rotisserie for the tub to allow the doors to be left on for increased stability during the tub removal from the chassis. I have already removed the engine and trans from the chassis and am currently working on the final strip of the suspensions and rear differential. I will then be moving on to frame welding and refurbishment. Thanks again.
Ron
KVH TR4/4A Door Check Straps Triumph 11
sundown TR6 1973 TR6 door check straps Triumph 3
S TR2/3/3A door check straps for tr3 Triumph 1
S TR4/4A TR4 Door Check Straps Triumph 4
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
Michael Oritt Door check installation Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
M BN1 door check replacement Austin Healey 9
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
HealeyDave Door Check Friction Adjustment Austin Healey 12
sundown TR6 Door check strap Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
G 6 door check noise Triumph 13
K door check strap Spridgets 10
me61ic Forum search and Door Check Strap ? Austin Healey 1
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
A Door check Lotus 4
W Broke check strap on door Triumph 4
mjobrien Door Check - Color? Austin Healey 2
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
F TR4/4A TR4 Question: Door check strap pin Triumph 5
Rob Glasgow Door Check Strap Austin Healey 12
This14u Spitfire Spit Door Check Triumph 3
M Door check strap repair Austin Healey 6
S door check strap attachment Triumph 15
6 door check strap Triumph 6
I TR6 Removing door check arm in TR6 Triumph 6
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
S TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
