Temperature sensor Help me
Riquet1963
Hello everybody
This is my first post in this forum!
I live in france and I have one Healey 3000 MK2 from 10 month
I need to change the dashboard because the previous owner had cut it to place a radio!
For that i need to remove "oil / temperature gauge"and remove the sensor located on the engine.
It's my problem and I have two questions
1: Have you one or more trick to remove this nut !
2: The sensor it's in contact with a water directly or in the cavity in the cylinder head?
See pictures
Many thanks in advance
Eric G
dklawson
I have no AH specific experience. However, I have made similar tools from sockets to the one shown in Peter Carbone's thread.
The only addition I can offer is that the "13/16 socket with flats" is a spark plug socket so they should be easy to find.
I 'made' a tool for this by cutting a slot in an appropriate-sized--guess it's a 13/16"--closed end wrench. However, not wanting to sacrifice a good tool I used a Harbor Freight--do they have those in France?--'cheapie' and, as mentioned in the link, it eventually spread apart.
Be sure to soak the nut in a good penetrating oil for a couple days if you can and maybe apply heat from a heat gun. I wouldn't use a propane torch, the temp gauge system is filled with ether, the capillary tube is fragile and overall it's very easy to break it.
RAC68
Hi All,
I totally agree with Bob on the use of rust penetrant being used prior to trying to loosen the sensor. Additionally, be very carful that you do not deform or break the copper capillary to attached to the sensor as it is extremely difficult to repair. Keep in mind that you are diminishing the inherent strength of the sock by cutting the slot and I have used a hose clamp around the lower end to help strengthen the socket when in the process of breaking the sensor loose.
I still have the socket along with other tools I modified to address specific Healey needs.
Ray(64BJ8P1)
R
Riquet1963
Hello
And for my second question?
In fact I search if I need a seal between this bulb and the water or this bulb is encapsulated in the cavity?
BR
Eric G
dklawson
Again, I have no AH experience. However, in other applications where the Smiths/Jaeger mechanical gauges are used the expansion bulb (sender) goes into the water jacket of the cylinder head, not into a dry space. The seal is typically made using mating tapered seats (female tapered seat in the cylinder head, male tapered seat on the expansion bulb.
A little bit of teflon tape or pipe sealant won't hurt.
Most of you have probably heard this story, but my dad--as usual--thought he could repair the sender for our BN2 during restoration. So, he bought some ether, poured it into the bulb and tried to solder it all back together. Not too surprisingly, the ether did what it will under those conditions and ignited, launching the bulb across the shop (it's roughly the size and shape of a 50-caliber bullet). He's lucky he didn't lose a proverbial eye; we sent the gauge and bulb to MoMa.
dklawson
You can make a DIY repair of mechanical temperature gauges IF the dead gauge (when cold at rest) has its needle against the lower stop pin. Follow the steps in the link below. I substitute dry ice for the salt/ice bath to chill the donor bulb. It's cleaner and colder. To date I've probably fixed about 6 mechanical temp gauges. I don't use open flames for soldering so there have been no 50-Cal projectiles in my garage!
MOSS printed an article within the last year or so explaining a different way to repair the mechanical temperature gauges. I would NOT use their method. Their method is just too dangerous when compared to the method outlined in the link below.
DIY Mechanical Temperature Gauge Repair Link
I don't believe my father would use a torch to seal a tube full of ether--he wasn't stupid--nor did I say as much (there are other ways to solder). He tried to reattach the bulb at the end of the capillary tube, or he might have pierced a hole in the bulb--the ether was gone when he attempted the repair--and tried to seal the hole with solder using a soldering gun (a pencil wouldn't be hot enough). This would have been difficult with the bulb in ice (but it is a good idea to use ice to cool the ether).
He did subscribe to Skinned Knuckles for many years; I might have a stack of them somewhere.
pkmh
A suggestion on how to remove your temperature sensor by making a home-made socket in conjunction with a hose clamp...(I do NOT advise using flame in attempts of removal unless you know what you are doing).
When I made my modified socket, I provided "doubled" the opening clearance (2X, at least), so that as one starts to loosen the hex nut from the probe, one can do so one edge of the nut at a time. In other words, loosening the nut means having to also loosen the hose clamp after each fraction of a turn of the socket to avoid shearing or damaging of the sensor coil. Same goes for reinstalling, of course.
PS.- I also recommend easing all edges of the modified socket to avoid potential cutting of the coil upon removal/reinstallation.
With respect to the Temperature Sensor Probe and if visible from my photo, I also have written the note (at right of 'Temperature Sensor At Probe') on how it is important to pull back on the coil just enough as required to avoid any unnecessary entanglement or snagging, (as was in my case, anyway). Your case may not be the same as mine was. In any event, I've learned patience when it came to removing in its entirety as well as reinstalling.
Good luck.
Paul
dklawson
Bob, I wasn't trying to insult you or your father. I apologize if it seemed that way.
As I am sure you read, the method of repair in the link I posted involves splicing the capillary tube. That is obviously much easier to achieve than soldering at/to the expansion bulb or the gauge. The amount of heat applied and the length of time the heat is applied is low and short respectively.
I located an updated copy of MOSS's article on mechanical temperature gauge repair and have provided a link to it below for those who care to read over their method.
Link to MOSS Tech Article on Mech. Temp Gauge Repair
Guess I should have added a disclaimer to my post:
NOTE: This statement in no way recommends the use of a blowtorch, propane torch, oxy-acetylene torch or flamethrower to (mildly and carefully) warm a fragile brass bulb full of a highly volatile and flammable organic compound so that a penetrant oil may more effectively do the job for which it was intended.
Welcome to The Forum, Eric!
Doug,
No problemo. Dad was a patient and meticulous mechanic, but he'd be the first to admit he 'screwed the pooch' many times. I didn't see him do this, but he told the story in such a matter-of-fact way it was pretty funny.
pkmh
Hello everybody
Thanks you very much for your advices
Operation is done..
BR
Eric G
Just as another piece of advice and for whatever its worth (from my experience)...As I removed my entire sending unit assembly from the car (and put it back in, for that matter), I was very ginger and subtle in straightening the entire length of the coiled portion and only as necessary as I was passing it through the firewall and out the dash.
I found it is just one of those components that doesn't really like to be "changed" in life once it is set. I also had to keep in mind it had to go back in and be reshaped again.
I remember something of a lolly pop candy commercial once..."How many bends does it take to break the center of a Sensor Probe (and go "POP?")". "It's a world I don't really want to know."
Paul
M Help... ! Coolant temperature sensor leaking.. Austin Healey 4
A MGB Stuck water temperature sensor MG 26
B Temperature Sensor Removal Austin Healey 10
N BT7 water temperature sensor removal Austin Healey 13
S BJ7 frozen temperature sensor to block Austin Healey 17
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
L Temperature sensor relocation in BE with A 1275 Spridgets 8
W Plugging the temperature sensor hole Spridgets 3
D TR4/4A tr4 temperature gauge/sensor reading Triumph 11
G Temperature Sensor Location.... Triumph 5
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
K TR2/3/3A Temperature Gauges Again Triumph 5
S TR2/3/3A Temperature Guage Triumph 3
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
Dave Richards Temperature Guage Austin Healey 11
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
