MGB B V6 Conversion Recommendations
69MGC
Hey Guys
Anyone have thoughts on the best B year to do a V6 conversion? I want to keep it below 75 for smog reasons. What is your opinion on a pre-rubber bumper year and any mods to the engine bay that may need to be done in order to get a V6 to fit.
Thanks
Mickey Richaud
Hey, Kev -
Having done one on a '69, I can tell you that it's not that bad. The rubber bumper Bs are easier, as the firewall has more room, motor mounts are different, and the radiator location is more forward.
On the chrome bumper Bs, you have to cut away the brackets where the motor mounts bolt up, relocate the radiator, and "dress" a couple areas of the firewall. Also, the steering shaft u-joint is too large and you'll need a smaller one, as the exhaust header will foul it.
Earlier chrome bumper Bs (pre-68, I think) also have narrower transmission tunnels, so that's an issue.
If you haven't already, check out British V8's website for lots of examples - http://www.britishv8.org/Photos-MG-Conversions.htm
And info: http://forum.britishv8.org/
Oh, and the GM 3.4 found in early model Camaros and Firebirds is the engine of choice, along with the Tremec T5 transmission.
Bill Guzman, at Classic Conversions, is the go-to guy for the installation kits, as well as lots of info: http://www.classicconversionseng.com/ Brian, at BMC also: http://bmcautos.com/
Good luck and let me know if I can help.
Mickey
69MGC
69MGC
Thanks Mickey for the quick response. I'll check out the sites you recommended and I'll post with any other questions as I move through the process. Thanks for the help.
Kev
billspohn
As said, any year of MGB works, though there is a bit ore work on the CBB. OTOH, the RBB needs a bunch of work if you want it to match the early cars in handling, so it is a toss up, pretty much.
The same engine also fits in an MGA with a bit more work (this one looks odd because it has the Jamaican body on it)).
69MGC
69MGC
Thanks Bill for the Input. Love the engine setup in the photo.. I'll keep you all informed.
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
zoohow TR6 Carburetor Conversion kit Triumph 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
R Smitty Toyota Conversion Angle Drive Austin Healey 16
P Positive to Negative Conversion Austin Healey 1
P Pos to Neg Conversion Austin Healey 1
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
D transmission conversion Other British Cars 1
W TR2/3/3A Wire Wheel Conversion Triumph 5
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
petnatcar Breather Hose Conversion Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye disk brake conversion Spridgets 10
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
Walter74 Throttle Cable Conversion Austin Healey 6
PAUL161 T-Series Dynamator Alternator conversion. MG 23
M Dynamo to "Dynamator" Conversion Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
H Shock absorber conversion Austin Healey 3
S MGB MGB engine conversion MG 27
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
J TR6 Moss HS6 SU conversion kit question Triumph 4
roscoe 5 speed conversion question Austin Healey 9
maxwedge5281 bought back my first nasty boy conversion!! Austin Healey 6
I Bug eye front disc brake conversion. Spridgets 5
steveg Cost of V8 conversion Austin Healey 34
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
M TR6 5 speed conversion Triumph 33
C AUF214 solid state conversion question British Motor Corp 0
I TR6 TR6 EFI Conversion Triumph 19
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
A AH 3000 rear disc brake conversion Austin Healey 28
I Bugeye generator/alternator conversion question Spridgets 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
JoeO 71 TVR Vixen V8 Conversion TVR 26
S TR2/3/3A TR3 with Ground Conversion Triumph 18
longbridgehealey Alternator conversion and tach Austin Healey 9
