Results 1 to 6 of 6
Thread: Blinking the Brake lights?
  1. #1
    Join Date
    Jan 2007
    Location
    Winnipeg ,Manitoba,Canada
    Posts
    1,975
    Thanks Thanks Given
    37
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Is there a gizmo available that I can install that will blink the brake lights a few times then stay on till released? Negative Ground.
  2. #2
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,235
    Blog Entries
    1
    Thanks Thanks Given
    47
    107
    Thanked in
    Re: Blinking the Brake lights?
    Quote Originally Posted by karls59tr View Post
    You'll hate me for this, but your foot will do that very nicely.
    Tom M.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  3. The Following User Says Thank You to NutmegCT For This Useful Post:
    karls59tr (11-30-2019)
  4. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,352
    Thanks Thanks Given
    8
    112
    Thanked in
    Quote Originally Posted by NutmegCT View Post
    Tom M.
    Not while you're firmly applying the brake, which IMO is when you need it most.
    Lots of gizmos available, here's an example I just found.
    https://www.amazon.com/blinker-flash...93699586&psc=1
    But I rolled my own, so no experience with a commercial model. One IC, one transistor, and a sprinkling of resistors and capacitors.
  5. The Following User Says Thank You to TR3driver For This Useful Post:
  6. #4
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    649
    Thanks Thanks Given
    3
    Thanked in
    Also, if you have not done it, I highly recommend putting in LED bulbs in the rear. They are so much brighter than standard bulbs. I like the ones from LiteZupp. They directly replace the old bulb. Also you would need a new turn signal flasher that supports LED bulbs. With the brighter LED bulbs you may not need them to flash.
  7. The Following User Says Thank You to TuffTR250 For This Useful Post:
    karls59tr (12-02-2019)
  8. #5
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,365
    Thanks Thanks Given
    13
    Thanked in
    I have used the GS-100A that sells for a couple of bucks on eBay:
    https://www.ebay.com/sch/i.html?_fro...be+turn+module
    Works fine with LEDs. I suspect that regular incandescents would light up and go out to slowly for it to be effective with them.
    If you do not want to convert to LEDs an alternative is to just use the strobe to flash an LED third brake light. That is what I did on this car:
  9. The Following User Says Thank You to Geo Hahn For This Useful Post:
  10. #6
    Jedi Knight mgedit's Avatar
    Join Date
    Jan 2009
    Location
    Kemptville, Canada
    Posts
    837
    Thanks Thanks Given
    1
    2
    Thanked in
    I also used that gizmo that Geo mentioned. Worked just fine to flash an LED third brake light on both a TR6 and TR3.
    Cheers, Mike
    Webmaster Ottawa Valley Triumph Club (www.ovtc.net)
    1956 TR3 - TS11537 (www.triumphowners.com/to-car/tr3-9/)
  11. The Following User Says Thank You to mgedit For This Useful Post:
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
