Spitfire Smoke Testing
FlyingCat
Hi, everybody. I have a 1980 Spitfire (1500 Federal), not that it may matter for this question. Does anybody have suggestions on smoking testing one of these engines? Thanks!
poolboy
There should be something on YouTube, if the specific car doesn't matter.
TomMull
The late Tappet Brother Tom Magliozzi from NPR "Car Talk" devised a procedure using one of his favorite cigars. Sorry I couldn't find the episode on line.
Tom
Graham H
What is smoke testing? is it an American tongue in cheek thing? I have no idea what you are asking.
Graham
NutmegCT
Jim_Stevens
FlyingCat
FlyingCat
I found a couple of places online that used a cigar, one where the guy actively puffed on it, and another where they used a transfer pumb, and even one where the guy built an elaborate pump using a pickle jar. I got that part down. What I'm looking for is where to blow it in at on my car.
FlyingCat
FlyingCat
I've tried that, and it works to a degree, but some of those leaks can be really subtle, and as poorly as it's running now it's hard to tell it's running any better.
FlyingCat
FlyingCat
It's the same principle as testing a sewer line for leaks, or testing your attic for leaks. You fill it full of smoke and then go outside to see where that smoke is coming out. With a car, you blow the smoke in... somewhere... and then see if any of the gaskets or hoses are leaking. There are several videos online that show how it's done. This is probably the best:
https://www.youtube.com/watch?v=GOhl4r0GSiE
What I'm wanting to figure out is where would be the best place to blow that smoke into my Spitfire's 1500 engine.
poolboy
When I had it done at a technical college..they stuck the smoke into the tail pipe...It takes awhile, but smoke will circulate into the engine thru which ever exhaust valves have openings.
PAUL161 T-Series Puff of blue smoke on startup MG 17
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
P TR6 Smoke Triumph 2
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
AN6-TX Exhaust Smoke Spridgets 15
NutmegCT blue/gray exhaust smoke Other Cars 13
4tecdog BJ8 Transmission housing smoke Austin Healey 14
M Mystery white smoke Spridgets 11
DerekJ Lighting circuit - the smoke's escaped from the wires.! Austin Healey 12
Keith_M Now the smoke is blue/gray Spridgets 10
Martinld123 Small Puff of Black Smoke When I Blip Throttle Austin Healey 6
JPSmit I accidently let the smoke out Restoration & Tools 5
F BJ-8 Generator Smoke Austin Healey 9
F White smoke and I cant figure it out. Spridgets 17
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
N TR4/4A oil smoke Triumph 4
bighealeysource smoke from overdrive on BN2 Austin Healey 8
BillyB62 TR2/3/3A Holy smoke - a PINK TR Triumph 24
Trevor Jessie I let the smoke out of the welder Spridgets 10
R smoke out of tail pipe Spridgets 46
bugedd Smoke Spridgets 9
JodyFKerr Wedge I might have let the smoke out [TR8] Triumph 25
M Holy Smoke! Triumph 8
J T-Series electrical heat and smoke from the switch MG 4
T Smoke from the tailpipe! Spridgets 20
Nelson Garage smoke alarm Spridgets 3
Gordon_Dedrick Help with Lucas smoke! Triumph 5
BugeyeNJ58 Smoke from valve cover? Gurgling Noise? Spridgets 4
M Smoke Triumph 5
athenssprite Smoke - oil burning Spridgets 5
athenssprite heavy smoke on start up - burning oil Spridgets 13
WillR wires and smoke MG 0
M AH 100-6 Generator- SMOKE! Austin Healey 7
B 74 XKE blowing white smoke. Jaguar 14
TexasSprite Smoke and Sparks Spridgets 0
Bayless Passed the smoke test! Other British Cars 3
J Excessive exhaust smoke Austin Healey 12
abarth69 Clear the smoke Spridgets 12
S EBAY SMOKE Triumph 8
Stewart Smoke, low compression I think I'm done for a bit MG 7
dklawson Spitfire Spitfire Dry Engine Starts-Need Smoke Explanation Triumph 3
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
T Smoke from Starter Solenoid Spridgets 9
MadRiver Blue smoke on startup? MG 8
Z white smoke question Spridgets 15
M electrical smoke from cowl vents Triumph 8
J Smoke - NO GOOD Spridgets 16
Baz Smoke...from the carbbies. Spridgets 11
S Help! Billowing white smoke?? MG 21
