TR2/3/3A Kast f cam...301466
karls59tr
I came across this camshaft in a box of parts. I believe it to be a full race cam made by Kas Kastner.Looks in good shape. How can I find out what the specs are? Is it possible to measure the cam lobes with a caliper gauge to tell how worn it is. 100_1921.jpg100_1927.jpg100_1928.jpg100_1929.jpg100_1924.jpg What would cause the flat wear patterns that you see? Is that normal. Any thoughts appreciated.
tinman58
It may be my computer but all the photos are blurry.
TomMull
To translate from Peterk's chart, the E cam is the last in Kastener's grinds (A to G I think) suitable for street. Your's is in the race category. Tom
Sarastro
As for wear, it's almost always obvious: pits, chips, and striations. I have seen camshafts reground so deeply that the heel of the cam is actually below the surface of the shaft, which would be a concern to me, at least. If you don't see any wear, it should be OK.
If you could post some non-blurry pics, we could help evaluate it.
Oh, and, Peter: thanks for that link. Maybe I'm out of the loop, but I was unaware of that site. That's a useful table.
K TR2/3/3A More pics of Kast Cam Triumph 4
J TR 4 Norris Cam 342S Spec Sheet Racing 0
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
T Spitfire Cam shaft Triumph 3
J MGB MGB cam, gear? MG 3
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
Marvin Gruber Cam shafts for 3000 Austin Healey 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
K Kastner "F" race cam. Racing 3
mgedit TR2/3/3A Cam Sprocket Bolts - Shoulder or not Triumph 6
B TR2/3/3A Positioning new cam sprocket Triumph 4
K TR2/3/3A Kastner "F" race cam again.... Triumph 3
