Results 1 to 7 of 7
Thread: Steering Column Installation
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Jul 2015
    Location
    Menlo Park, CA
    Posts
    45
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Iím installing the steering column on my BE. It appears the openings of the column tube are different diameters. Iím a little uncertain regarding which end of the Ďcolumn coverí goes toward the steering rack and which goes toward the steering wheel? Iím thinking the larger end goes to the steering rack and the smaller toward the steering wheel?
    Is this orientation correct or is it small end to rack and larger to steering wheel?
    I also see the orientation of the rubber boot over the steering rack coupler in parts books at first I thought this also went in the firewall to support the tube. Iím thinking the firewall must have a grommet instead?
    Thanks for assistance.
  2. #2
    Senior Member Desert Rat's Avatar
    Join Date
    Jul 2016
    Location
    Las Vegas, Nevada
    Posts
    69
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Steering Column Installation
    The Moss catalog show the dust extruder over the coupler but it actually fits in the hole in the firewall for the steering column.
    I donít remember where the big diameter end goes, Iíll open the bonnet tonight and look.
  3. #3
    Join Date
    Jul 2015
    Location
    Menlo Park, CA
    Posts
    45
    Thanks Thanks Given
    Thanked in
    Thanks! It may be difficult to tell by sight as the diameter difference is slight. But there must be a reason for it?
    The felt bushings that go on top and bottom of column tube are different size not sure how that relates as well.
    Thanks
  4. #4
    Join Date
    Jul 2016
    Location
    Las Vegas, Nevada
    Posts
    69
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Mine is installed but it looks like big end at the steering wheel and tapers down to the rack. Youíll know if the clamp under the dash is loose.
  5. #5
    Join Date
    Jul 2015
    Location
    Menlo Park, CA
    Posts
    45
    Thanks Thanks Given
    Thanked in
    Good point.
    Thanks for checking and reporting.
  6. #6
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    388
    Thanks Thanks Given
    10
    Thanked in
    I have one sitting against the wall. May be MKII but the clamp is still on it. The steering wheel end has a small rolled indent about 3 inch from the end. I cannot see a taper on it or the one in the car.
    If yours does not have the rolled indent look for marks where the mounting clamp was installed about 8 inches from the end.
    As mentioned before the rubber boot goes into the firewall. Nothing over the attachment to the rack.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  7. #7
    Join Date
    Jul 2015
    Location
    Menlo Park, CA
    Posts
    45
    Thanks Thanks Given
    Thanked in
    Thanks, its hard to see difference in inside diameter from outside, it is very slight.
    i do have the grooves on both ends of the tube. I thought there was a rubber boot on the connector to the steering rack?
    otherwise the tube just fits over the connector clamp?
    The lower felt bushing must then fit above the connector clamp in the tube?
    it looks like if there is no rubber boot on the clamp the tube must rest against the plastic bushing surrounding the clamp?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
