Bonnet Striker Pin Assembly
Lin
I mounted my bonnet after a total disassembly and then restoration of my car a little more than ten years ago. I recall that getting things aligned properly was a bit fiddly. I am now installing a different bonnet (long story) and my photos, indexing holes and etc. are only somewhat helpful since the “new” bonnet doesn’t have the indexing holes and the alignment is a little different.
I have the bonnet secured to the hinges and it seems to be fitting pretty well side-to-side and front-to-back. Of course, the front is a little low since the striker assembly is not yet mounted. Can anyone who has been through this offer any tips or suggestions on how to best proceed? Alternatively, pointing me to a reference on this subject would be great. There sure isn’t much of anything in the shop manual about it.
Thanks as always!
Lin
Lin
Lin
Just a word of thanks to those who responded to my appeal for tips to install the striker pin assembly for the bonnet. I appreciate all responses but especially wanted to thank Roland Wilhelmy for reminding me about Roger Moment's article entitled "trial-fitting Individual Parts." Roger's suggestions about how to install the pin assembly are detailed and offer warnings on what to do to avoid problems.
Kent Lacy suggested "covering the striker hole with tape. Run your finger around the taped hole until it’s visible. Put a drop of paint on the tip of the striker and close the bonnet slowly until the paint drop is in the center of the hole on the tape. Replace tape each time it’s not correct. Trust me you want it to work the first time." I did this and found this to be a great tip. The photo shows my first attempt, but I was then able to easily adjust the position of the pin to get it centered. The unlocking mechanism then worked perfectly on the first attempt. Thank you, Kent!
Healey Rick suggested doing basically the same thing by getting under the car and looking up to see if the tip of the striker pin was in the center of the retaining plate, but while this would certainly work, the tape was very easy and probably more precise.
Thanks to all,
Lin Rose
blueskies
Installing the hood (bonnet) striker assembly was one of the jobs undertaken today on the 100-6 reassembly project. I recalled reading the tip above about putting masking tape on the lower part and paint on the tip of the striker. That method didn't work well for me, possibly because the paint used was too thin and ran off. A minor modification to the method solved the problem. It occurred to me that a dark colored grease would work in place of a heavier paint. A bit of grease on the fingertip, deposited on the outer circle of the upper striker, did the job well. It left a nice circle on the masking tape, showing exactly the direction and amount of adjustment required for an accurate meshing of the upper and lower parts. Locked and released well the first time the hood was pushed down all the way.
Lin
Lin
Blue skies,
I am sure grease will work, but rather than paint I used some of my wife’s nail polish. I used “That’s Berry Daring,” but I almost used “Blue My Mind.” It is just a matter of personal preference. Nice applicator and the polish is pretty thick, staying where you put it. Hah ha, chuckle, chuckle.
Lin
S M Series Bonnet Striker Pin failures TVR 4
wangdango Bonnet striker plate detail picture/advice? Austin Healey 0
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
R bonnet hinge R or L Austin Healey 2
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Bonnet Latch/Release Adjustment Austin Healey 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
fmichaels Bonnet hinge holes Spridgets 4
Rhodyspit75 Bonnet gas struts Spridgets 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
C Under boot and under bonnet paint? Austin Healey 7
D TR2/3/3A bonnet safety catch Triumph 4
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
W Electrics, fuel system, under bonnet temp. Austin Healey 3
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
anarchy99 Bonnet / hood fit question... Spridgets 2
