TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke.
TuffTR250
I am seeking advice on best and easiest method to repair a broken spoke on my TR3 steering wheel. I have attached pictures of the broken spoke. From what I've seen on the forums, it appears I will have to break away the "bakelite" and weld the spokes to the rim, and then use some form of epoxy to reform the steering wheel where I remove the "bakelite". Thanks for any advice!
DornTRoriginal
I agree these are hard to find. There's a British company that supplies a nice replacement, I am at a loss to find their contact info, I think you could try Macy's garage too. https://macysgarage.com/wood wheels.htm.
TR3driver
Great Pumpkin - R.I.P
If all 4 are broken at that point, what are the chances that the others are about to break? What you've outlined is the only way I see to repair it, but I think David has the right idea : Look for a good used one from another car. That looks to be a non-adjustable wheel, and they are relatively common in good condition. (For some reason, the adjustable ones fail much more often.)
sp53
Wow I remember the Roth brothers from years ago; they actually had a junk yard of tr3 and tr2 and some tr4 open to the public.
Andrew Mace
1. I'm not sure it's worth the effort to properly and safely repair that. As others suggest, a used one should not be that difficult to locate.
2. I'd be very, very concerned about the integrity of that wheel (and any sort of "repair" you might be able to make). I don't think I'd want the rest of the rim to fall off while driving! (See also #1)
bwm1974 Lower inner fulcrum pin seeking thoughts & advice Spridgets 1
T Novice seeking advice on starting problem Spridgets 32
blacknite3 MGB New MGB owner seeking Heater advice MG 12
A Potential Owner - no knowledge. Seeking advice! Austin Healey 6
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
R Seeking Upholster Recommendation Austin Healey 4
woolfman Seeking info on GAN3L28111 - Owners prior 1996 in the US Spridgets 2
T General TR Seeking good luck Triumph 65
J Clutch Problem - Seeking Input Austin Healey 4
C RestoRod 100-6 Seeking Guidance... Brakes to Start Austin Healey 15
RickB Seeking HIF4 gurus - need help! MG 47
J Seeking tri carb help Austin Healey 16
M Seeking an operational BE fuel gauge Spridgets 4
M Seeking 3.9 or 3.7 diff case or just gears Spridgets 3
B Time to go racing again - seeking clean Spridget Racing 32
MadRiver TR5/TR250 Deparately Seeking TR-250 Showroom Poster Triumph 8
B Seeking AH 3000 Inner Door AL 'Closeouts' Austin Healey 7
toysrrus Seeking to Buy: 3' x 5' Triumph Loggoed Flag: Triumph 4
JPSmit Thinking about 5 speeds - seeking understanding Spridgets 12
N Desperately seeking service - Long Island/NYC Jaguar 2
B Seeking Bugeye in Southeast Spridgets 0
G Desperately seeking sympathy... Triumph 14
Moose33 seeking out a thin intake manifold.. MG 3
CDK Seeking Rally Car History Austin Healey 5
J 2003 XJ8 Soverein seeking input Jaguar 5
Randy Harris I'm seeking an E Type Jaguar 2
H Advice asked on Healey not starting Austin Healey 0
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
