Changing Lock Barrels
red57
Hi all, I hope someone has done this and can help.
I found, after getting a Heritage Certificate for my '60 BT7, that it still had the original ingition lock with numbers that match the Cert. (the original key also has the same lock number stamped in it) and the same key works in the trunk lock - good news!
Bad news is the ignition lock body has been damaged by excessive heat and needs to be replaced, the other bad news is the trunk handle chrome is bad and the escutcheon is cracked so it also needs to be replaced.
Changing the lock barrel in the ignition is easy - with key in lock & turned on, there is a small brass button seen thru a hole in the lock body that you push and the cylinder slides out.
My problem is I there is no hole that I can see in the side of the trunk lock to press a pin inside - does anyone know how to change the lock barrel in the trunk lock? Do I have to grind the 'pinches' off the square shaft and remove the escutcheon to find a hole to access a pin? And, if I grind the 'pinches' off to disassemble, how di I re-assemble? I don't mind destroying the old handle and escutcheon to get the old lock barrel out but will I be able to reassemble the new latch and escutcheon with the old lock barrel in place?
I really would like to keep the original key that matches the Cert. and keep both locks keyed the same. I appreciate any help.
Thanks,
Dave
John Turney
There is a pin under the cup that is held in place by those pinches. That's the "key" to getting everything apart. My friend replaced the pinches with tack welds to reassemble.
red57
red57
Thanks John, I though there might be a pin but wasn't ready to destroy the old one just yet. Tack welds make sense to me
Thanks again,
Dave
red57
red57
Hi, Thanks to John Turney's info above, I was able to disassemble my old boot/trunk lock (new one is on the way). I thought I would post a picture of the internals with my observations in case someone else ever needs to replace theirs and wants to keep it keyed the same as the ignition. Other than John's response I found no information on how to disassemble so I laid it out and took this picture to show the details (warning - I'm no Randy when it comes to photo-documentation :smile:)
After grinding down the 'pinches' in the 5/16" square shaft, the steel cup comes off and behind it there is a steel spring washer and two slightly conical brass washers, then the escutcheon.
The handle with lock simply slides out of the escutcheon.
You can see two pins, the left one in the picture holds the square shaft in (and doesn't need to be removed, but I didn't know that until after I had removed it). This pin is knurled on one end and in tis case the knurled end was on the bottom as things lay in this picture which would be the left side when on the car (don't know if they all went together this way or if it even matters).
The pin on the right is the one that holds the lock barrel in it is brass and is not tapered so it can go in & be tapped out either direction. You can see the groove at the left end of the lock barrel where the brass pin rides to prevent the lock barrel falling out. At the very left tip of the lock barrel, the small pin extending to the left rides in the slot in the lock plunger
I hope this may help someone else someday.
Dave
red57
red57
Steve,
Good idea, a roll pin should be a good option - I don't think there is anything close enough to interfere but I will check.
Thanks,
Dave
Gatheringtree
Thanks,
Dave
Thank you.
I bought the set of 5 matching locks and handles on Moss Motors. I needed to know how to switch the ignition key cylinder. I will simply switch out the glove box, doors, and boot. Appreciate these photos and instruction.
BigGreen
BigGreen
Gatheringtree
Thank you.
HEADS UP: the supposedly-matching handle (from Moss Motor) for the Triumph TR3 boot has the wrong hole spacing. The space between the holes is off by about 3/32". This was just beyond redrilling and countersinking the base. Besides this would mess up chrome. What I had to do was re-used the old base, which was in decent condition. But then, the new square turning pose was too short to engage the lock. This was because, coupled, with the old base, shortened the length of the square rod. Therefore, I had to cut off a small piece of the old square turning post and attach them together with a 3/4" long 10-32 machine screw. I got it working, but it is a bit of a rickety mess. I need to go back and use a strong lock-tite to make the connection between the square posts more solid. Disappointing, however, I do not know any other source to get a new boot handle. (I have not exchanged the door handles yet, and only hope that the holes line up there as well.
mezy
could you not make a longer square bar, I dont know the size but possibly a household handle may be the same size
Gatheringtree
That is very possible. The hardware store may also carry square rod. I'll check both before taking this to get welded or pulling out my 110V wireless welder. Thanks
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
T Kilmartin Changing Ownership Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
bobh Changing Transmission Oil in 10 minutes Triumph 8
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
theleisure Changing Out Front Bushings Spridgets 5
R Changing Motor Mounts Triumph 6
BritcarsUSA Changing 5/8 to 3/4 Midget filter adapter nipple? Spridgets 4
rchakr Changing Rear Springs Triumph 6
beaulieu changing an old car to E85 Restoration & Tools 14
T Changing fluids Triumph 16
G Changing bearings Triumph 7
B Changing to Silicone Brake Fluid Spridgets 18
G Changing Horses in Mid Stream.... Triumph 47
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
T Changing front bolt pattern? Triumph 9
19_again changing right angle drives MG 1
G Changing my Sway Bar Triumph 11
S Fuel Pump, changing ground Spridgets 3
