Thread Locker on Shock Bolts?
jman15
Saw another post on shocks leaking oil and requiring tightening and it got me thinking about whether I should use thread locker (Locktite Red-Medium?) on the bolts holding the shocks to the frame. It is common for us to check these bolts with some frequency or prior to a trip and it is also common for them to need to be re-tightened. So I'm thinking this would be a good idea and don't see a downside to it. Your thoughts?
FYI, only planning to use thread locker on the shocks since they are subject to a lot of constant shocks :joyous: (couldn't help myself there).
On the front shocks, I use Grade 8 flat washers under Grade 8 bolts doused with blue threadlocker and torqued to 35lb-ft; haven't had one come loose in many tens of thousands of miles. There's a 'simple physics' explanation: the same clamping force is applied over a greater area of the shock 'foot' with the flat washers (split washers dig into the soft metal which relieves tension, allowing the shock to work loose). Didn't work on the rear shocks though, probably because the bolts are under shear instead of tension; I'm currently using split washers but have some other type of fancy lockwasher--forget the name--I'll install when I get a chance.
steveg
I'm using NordLock washers under my front shocks for the last couple of years. No loosening.
steveg
Steve, Have you noticed if the Nordlocks--that's the washer I was trying to recall the name of--left any impressions in the whatever soft metal the shock bodies are made of?
Bob - haven't had them undone for a long time and was not concerned at the time with wear-and-tear from the lockwashers. I believe the shocks are aluminum.
Any impression can't be any worse than the original split-ring lockwashers with their barbed ends. Those gouge out a little every time you undo them.
FWIW, I'm using belleville washers on my intake manifold studs, carb studs and rear axle pumpkin studs. No loosening there either.
steveg
Wouldn't advise Red. Use Orange or Blue - you can undo those without heat.
vette
More than 15 years ago when I rebuilt my shock towers I reinstalled the shocks and used blue thread locker on the threads. I use to think about retorquing them but never did because I didn't want to disturb the thread locker. After all these years they have showed no signs of loosening. I check the front end for quality and tightness every spring but have never put a wrench back on the shock bolts. Shocks have not moved and nothing indicates anything loose.
Good video on the anti-loosening properties of different washers:
I'm glad I watched this video; I had no idea Nord-Locks need to be stacked (looks like the pack of 10 I had to buy to get 8--I'll probably lose at least one--will be worth it).
I'd like to think I'm smart enough to know by looking at them but, you know ...
Editor_Reid
Platinum
Interesting video/advertisement. My takeaway is, "We're all gonna die!"
Seriously though, since no Healeys (or any other cars?) were made with Nord-Lock washers, and since mostly the cars stay bolted together, other means of keeping bolts and nuts connected are obviously working. Assuming that it's not simply because by now they're all rusted together, I'd be inclined to think that a failure to adequately torque them when installed is the major culprit. Maybe followed by using incorrect or damaged/worn hardware upon reassembly.
Faulty conclusions?
steveg
Over the years, I've had plenty of Healey friends/acquaintances who've had loose (or stripped) front or rear shock bolts.
If one wants to look original, one could use the split ring lockwasher with threadlocker.
I had tried all sorts of "solutions" before someone on the forum suggested the Nord-locks. I would get a clunk in the rear after a couple of months. Part of the problem was getting a tool into the thigh space. available. The Nord-locks have been on for 4 years and have not loosened and caused the once familiar "clunk". I intend to use them on the exhaust system the winter.
J
jman15
Thanks Steve. Will drop the idea of using the Red thread locker and go with either orange or blue. Or perhaps reconsider it all and go with the Nordlock approach. Sounds like you've had good luck with the Nordlock washers and based on what others have said it seems like an even better solution. Come spring I'll check out my options and price the Nordlock items. Plan on doing a brake job on front so will do all at same time.
Thanks
Jim
Patrick67BJ8
do you have a part number you used when ordering them?
thanks
Faulty conclusions?
IIRC, 'routine' maintenance for Healeys--and all British cars, probably--per the manual involved checking/tightening many of the structural fasteners, including shock bolts every couple thousand miles (along with greasing all grease-able fittings, filing fuel pump points*, changing out distributor points and spark plugs, changing out coolant, etc.). Anything that reduces the maintenance burden with more modern solutions is a good thing for me (I currently maintain 8 cars/trucks and 2 ancient tractors).
* Norman Nock said it was part of, IIRC, the 10-thousand mile maintenance to remove the fuel pump, clean the points and re-adjust the diaphragm.
twas_brillig
I like to use Loctite Blue on pretty much everything, including bolted connections with lockwashers. It`s easy, and (compared to the man-hours etc.), cheap. Doug
(and I can`t resist: I`m `shocked`that there have been no more bad plays on words since jman15`s opening query. I guess that there`s just too many ùps and downs`in suspensions systems and their `threads`on the Forum...
twas_brillig
Good grief! `Damper`! I`m jealous. Doug
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
JimLaney Anti-seize or Thread locker ? Spridgets 2
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
C My 2500M progress/questions thread TVR 5
JFS Wedge Stripped gearbox filler hole thread Triumph 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
charlie74 Wanted Thread restorer kit Triumph Classifieds 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
J TR2/3/3A such strange thread on gear shift knob Triumph 12
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JPSmit Spridget thread question FORUM Navigation Questions 2
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
Editor_Reid Parts List Thread Now "Sticky" - parked at the top of this list of subjects Austin Healey 0
Boink Rolls-Royce head replacement thread... Other British Cars 0
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
rvm Annulus shaft thread measurements? Austin Healey 12
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
nevets How do I unsubscribe to a forum thread??? FORUM Navigation Questions 2
B General Tech Waking up a sleeping car thread MG 1
W TR2/3/3A Glaciers move faster - my build thread Triumph 0
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
B Stripped Thread in Gas Tank Austin Healey 26
J anybody tell me why this thread closed? Austin Healey 4
T TR2/3/3A Another wheel bearing thread Triumph 5
Boink Waterless Coolant - thread from the AH forum Spridgets 18
Rut TR4/4A steering shaft/nut thread size Triumph 5
Editor_Reid New "Parked" thread at the top Austin Healey 0
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
B TR2/3/3A end of me water pump thread Triumph 2
Elva164 Michael's Vintage Racing video thread! Racing 5
JPSmit Following the Car Tunes thread - "spotted" Spridgets 4
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
JPSmit Spring recommissioning - JP's project thread Spridgets 11
T Vacuuming [prompted by Saxman's thread and Nomad's heater hose suggestion] Spridgets 2
